Go to Post For any coaches weary of choosing human players this year because you're worried they might lose their cool mid-game, a good indicator of someones ability to keep focused is their attitude while playing video games. - BradMello [more]
Unread 02-02-2009, 12:11
domoarigato's Avatar
domoarigato domoarigato is offline
Team #1208 CCO
AKA: Coony
FRC #1208 (Metool Brigade)
domoarigato is an unknown quantity at this point
We're trying to lose weight...
We're over weight by quite a lot and were wondering if we could take out some of the unused cRIO module-thingies...? They don't seem to really serve a purpose that I can see... unless there's like some base code that runs in them in the background that I don't know about....? We weighed them and with the three extras removed we could lose around a pound, which would be good....
Unread 02-02-2009, 12:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: We're trying to lose weight...
The only modules that you need to leave installed on the cRIO are the 9201 Analog module in slot 1 with the battery monitoring jumper (<R64>) and the Digital module in slot 4 with the sidecar attached to run the Robot Signal Light <R58>.
All other modules can be removed if your team is not using them.
Unread 02-02-2009, 12:23
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
How much is quite a lot?
Unread 02-02-2009, 12:25
JoeArnold's Avatar
JoeArnold JoeArnold is offline
FRC #1361
JoeArnold will become famous soon enough
I see no problem with removing the extra cRIO slot things, but how much overweight are you exactly?
Unread 02-02-2009, 12:32
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Just in case:
Remember, the battery + bumpers are not weighed.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 02-02-2009, 12:36
Team #1208 CCO
AKA: Coony
Yeah we're still like eleven pounds over last time it was counted... And that was without the bumpers and battery. > . > Been careful not to add too much stuff on it from the beginning, but didn't take into account all the lexane or whatevertheheckit'scalled stuff that we had to put around the electrical board and all, which is what's going to put us over....
Unread 02-02-2009, 13:36
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
For the future, you should remember to plan out your weight from the beginning of the season and the design process. Allot for the drivetrain, the electronics, and everything else you're planning to add. Try to keep the estimated total around 100 lbs because you're always going to end up needing extra weight in the end. (:
For now, if removing the unused modules is only saving about a pound, you should work through the entire robot design with the team and see where you can save weight.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 02-02-2009, 13:42
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Does your team have an air compressor on your robot? If yes you could consider removing it if you can find a way to have enough air for an entire match stored in your air tanks. Also you may want to consider removing air tanks if possible.
Another thing you may want to consider if you are using an Andymark toughbox or an Andymark supershifter is converting the large spacer block to aluminum standoff spacers.
If these solutions do not apply or are not sufficient enough, to help us help you can you please post a picture of your robot so we can see what other lightening options are available?
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
11 pounds of lexan is a LOT of lexan. Our basket has solid lexan sides right now and weights in at 10.6 pounds. I think it might be some other things that put you overweight, or you need to check your weight estimates.
Wetzel
Viva Olancho!
Unread 02-02-2009, 13:47
pschre's Avatar
pschre pschre is offline
Teacher Coach
AKA: James Schreiner
FRC #0806 (Brooklyn Blacksmiths)
pschre will become famous soon enoughpschre will become famous soon enough
Send a message via AIM to pschre
Some general weight loss tips:
The accumulation of steel nuts, bolts and washers can be significant. Since robots cannot extend past the bumper perimeter this year, you may find that 1/8" aluminum rivets will suffice to fasten surfaces together that won't provide much structural strength. Aluminum bolts are lighter but more expensive, though my team has never used them. If you're using a lot of corner brackets, those can be pretty bulky. You could buy some 1/8" thick aluminum strap, 1" or 2" wide, drill holes and/or bend into an L, and they will do a good job in many instances. As far as aluminum bar stock, T-slot extruded aluminum is about 2 feet per pound, whereas hollow square tubing is about 3 feet per pound (both at 1" square).
I don't know how thick the lexan you're using is, but to mount and shield your electronics you can probably go as thin as 1/8". This is the first year that my team has varied from 1/4", we are using some 1/8" thick and some 1/2" thick for places we need the strength (1/2" thick lexan is still lighter than 1/4" thick aluminum plate, methinks).
Finally, there are always good old speed holes. Just don't go overboard and damage the structural integrity. Figure out the volume you'd be drilling away, look up the density of the material, and think if it would be worth it.
Overall, since robots cannot extend past the bumper perimeter, my team has the feeling that we can be a little less RTAD (Robust To A Degree).
"In this life we cannot do great things. We can only do small things with great love." -- Mother Teresa
"You give yourself to us, O Lord, then selfless let us be, to serve each other in Your name, in truth and charity." -- Robert E. Kreutz, You Satisfy the Hungry Heart
"You have the right to work, but for the work's sake only. You have no rights to the fruits of work. Desire for the fruits of work must never be your motive in working. Never give way to laziness, either...Work done with anxiety about results is far inferior to work done without such anxiety, in the calm of self-surrender...They who work selfishly for results are miserable." -- from the Bhagavad Gita, quoted in Educating Esmé
Unread 02-02-2009, 13:59
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
another thing you can do is bore out the center of the toughbox axles, you can save a little that way, but you need a very good drill press for that. also this year the wheels do not need 6 of the screws to hold them to a hub or a sprocket, because you can not torque the wheels very much. we only have 3 bolts holding the wheels to the sprockets. another thing you can do is step down to 1/4 pitch chain.
295 Team Captain
Unread 02-02-2009, 14:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Lots of great suggestions, plus you have two weeks still to figure it out!
Pictures of your robot would be a great help, if you are looking for more specific ideas about easy ways to lose weight.
Unread 02-02-2009, 14:04
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
We have used them in the past on 461, and it does help a bit, but you have to be very careful--they are quite a bit weaker than their steel counterparts, so you want to be careful to only put them in places where the load won't overwhelm them.
Unread 02-02-2009, 14:08
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
I'm not sure what it's called but there is a plastic material that is in a cardboard like arrangement (two sheets with vertical supports in between). My team used this last year to save wight it weights 1/5th as much as lexane (used before). That should save some weight. (6 pounds roughly) Then you need to trim about 2 pounds...
Is now an engineer thanks to FIRST.
Unread 02-02-2009, 14:09
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Along with the types of bolts, think about the length as well. If you only need a 1" bolt for full engagement with a nut, there is no reason to have a bolt longer than 1". You can either shorten the bolt by replacing it or taking a hacksaw and elbow grease to it.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
awesome frame needs to lose weight B.Collette General Forum 3 01-02-2009 15:57
HALP! autonomous I am lose Shadow_Cat Programming 4 31-01-2008 21:37
How to lose that extra weight (Was: Major Help!!) dagger Technical Discussion 16 14-02-2006 00:26
Did you lose a camera? KathieK Championship Event 1 26-04-2005 11:39
