Go to Post Dangit Jim, we are engineers not politicians. - Andrew Schreiber [more]
Unread 02-02-2009, 13:31
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
Bumper Corner Braces
Hey all,
Sorry for starting another discussion about bumpers, but I was wondering if there was any legal way to attach adjacent bumpers. I understand from "<R08> O." that the backing may not attach to each other, but what about mounting a brace such as the one seen in the attachment. The brace would be within the bumper perimeter, but would have to be attached to the backing (ie, not removeable) to uphold its purpose. Would this be a legal piece on the bumper assembly and count toward the bumper weight?
Essentially, we want to wrap the fabric around the corners of the bumpers so there isn't a section of soft noodle hanging off the end that another robot could unintentionally rip off. It would be best for assembly and durability (specifically when attaching and removing bumpers for inspection) to attach adjacent bumpers. This would result in two bumper pieces (one each side) to attach to our robot.
Name:	bumper brace.JPG
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 02-02-2009, 13:34
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper Corner Braces
The brace could be part of your ROBOT, but not part of your BUMPER. When you take the BUMPERS off for size and weight, the brace stays on the ROBOT.
(since 2004)
Unread 02-02-2009, 13:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We considered having the "soft" parts of the bumpers wrap around the corner, but it looks to me like the hassle of making it this way, and then having to deal with those connected bumpers when removing and installing the bumpers for inspection, or for fixing the robot in a hurry, would negate any benefits.
Unread 02-02-2009, 13:41
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Talking Re: Bumper Corner Braces
I agree with Gary.
However, I have seen teams create a bumper assembly that consisted of two or more sides of their robot perimeter's bumpers held together at the corners by angle stock like you are talking about. If you are determined to proceed along this path for the design, I suggest that you submit a question to the FIRST Q&A forum.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 02-02-2009, 13:51
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
One of the clauses in <R08> (I wanna say N but not sure) demands that you use a segment of verticle noodle as a corner, not connected horizontals.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 02-02-2009, 14:23
BenB's Avatar
AKA: Ben Bennett
Thanks for your responses. I have asked the Q&A. For the attachment to the robot, we were considering a simple slide and lock system, so the bolts never have to be completely removed (as a second thought, removing the bolts would increase our weight limit..).
Although the rule only says "may" not MUST, it also gives other suggestions such as wrapping the noodles around the corner or beveling the ends.
Originally Posted by <R08> J.
Corners and joints between BUMPER segments may be filled with short pieces of vertically oriented pool noodle, by wrapping the pool noodles around the corners, or by beveling the ends between adjacent segments so they form a tight and complete protective surface (see Figure 8 – 2).
Unread 02-02-2009, 14:31
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Hurray another bumper thread!
Originally Posted by GDC
If the vertex forms a corner of the BUMPER PERIMETER, then it must be protected by BUMPER segments (on both sides of the corner). If the bumper segment does not follow the BUMPER PERIMETER, then it is not in compliance with Rule <R08>, and would just be considered extra padding.
This seems to make the case that you don't need a vertical noodle?
Is now an engineer thanks to FIRST.
Regolith Field Corner Dimensions MDiff Rules/Strategy 2 20-01-2009 07:14
pic: me without braces! mrbob1000 Extra Discussion 2 01-08-2008 15:37
autonmous corner or center dan da' geekman Rules/Strategy 55 09-01-2006 14:48
Writing Corner Mullet Chit-Chat 7 06-03-2003 20:56
