Go to Post Last I looked, FIRST wasn't an acronym for inspiration and recognition of robots. It was and is an acronym for inspiration and recognition of science and technology. - JaneYoung [more]
Unread 02-02-2009, 15:34
SamRI SamRI is offline
FRC #2443
SamRI is an unknown quantity at this point
Microswitch 2009
Does anyone know how to connect the microswitch sensor you get in the 2009 kit
Unread 02-02-2009, 16:27
Re: Microswitch 2009
Connect it between the ground and signal pins of a Digital I/O. The Digital Sidecar's built-in pullup resistor will provide a logic 1 on the input when the switch is open, and closing the switch will give a logic 0. There is a Common terminal on the switch; wire that to ground. Use either the Normally Open or the Normally Closed terminal as the signal, depending on whether you want the switch to close or to open when activated.
2009 Teams Tomatosoup General Forum 2 22-12-2008 11:58
FIRSTBase 2009 tanmaker General Forum 9 09-11-2008 01:30
2009 Registration Greg Needel Regional Competitions 64 15-10-2008 21:49
Microswitch problem SoD Programming 15 01-02-2007 11:55
