Downloading error
I was able to download initial code that made a motor drive but now when I go to download new code to the robot, WindRiver says that new code was downloaded to the cRIO but the robot responds as if no new code was downloaded. Am I downloading the wrong file to the cRIO in the Window --> Preferences drop-down or am I compiling it wrong? I had heard that the .out file should be compiled? Where is this file?
Re: Downloading error
You have to tell Wind River exactly which .out file to download in the Window --> Preferences -> FIRST Downloader Preferences menu.
No matter what project you are working on, when you tell it to download, that's the file that's going to be downloaded. You can locate the proper .out file using the Project Explorer or File Navigator in the left windows. The File Navigator will probably have several .out files listed with the full path, just make sure you pick the one with the same name as your project. Last edited by Mark McLeod : 02-02-2009 at 17:26. |
Great thanks a lot.
| [FTC]: Error on downloading sample codes in Labview | TeamCaution | FIRST Tech Challenge | 4 | 02-12-2008 15:05 |
| Error in code light on, trouble finding error | Bryan Herbst | Programming | 16 | 12-10-2007 21:59 |
| 180:Error: syntax error help! | seanl | Programming | 8 | 04-02-2007 11:31 |
| stupid Array error: Error [1300] stack frame too l | Validius | Programming | 7 | 27-01-2006 10:53 |
| Code error on RC after downloading "bells and whistles" version of Kevins camera code | DanDon | Programming | 6 | 10-01-2006 18:07 |
