Go to Post I have yet to see an error where disabling the watchdog was the correct decision. - EricVanWyk [more]
Unread 02-02-2009, 16:40
nyindojin nyindojin is offline
FRC #3059
nyindojin is an unknown quantity at this point
Question How to hook up the tubing with the brass fittings
hi this is team 3059, rookie year, and thank you for this chance... we have decided we want to use a pneumatic system to control the lift and tilt of a box to dump the balls on the robot, however we do not understand how to connect the tubing with the brass fittings, then to the regulators, cyliders, etc.... any ideas or pictures will be greatly appreciated. ..... Thank you. - Team 3059
Unread 02-02-2009, 16:47
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: How to hook up the tubing with the brass fittings
In the past, a number of "quick connect fittings" were provided with the kit, which screwed into pneumatic components on one end, and had a tube connection point on the other. Unfortunately, these were not provided this year.
They were along the lines of these: http://www.smcetech.com/CC_host/page...35b76a72552d34
Trouble with the treads in the brass fittings? CalTeach General Forum 2 31-01-2007 07:57
How to hook up a Police light on the Robot?? xur2007 Technical Discussion 4 13-11-2006 18:27
How do you hook up the camera? SpeakerSilenced Programming 18 16-02-2005 15:00
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
