Go to Post Life is not about avoiding risk, but managing it. - dtengineering [more]
Unread 02-02-2009, 12:44 PM
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
Accelerometer class - isn't reading zero at rest?
Do we have a bad KoP board or the code is wrong or missing some setup?
// Declare variables for the 3 axis accelerometer (2 channels wired)
Accelerometer *m_accelerometerX;
Accelerometer *m_accelerometerY;
// create accelerometers
m_accelerometerX = new Accelerometer(2);
m_accelerometerY = new Accelerometer(3);
//m_accelerometerX->SetSensitivity(0.0);
//m_accelerometerY->SetSensitivity(0.0);
//m_accelerometerX->SetZero(0.0);
//m_accelerometerY->SetZero(0.0);
accX = m_accelerometerX->GetAcceleration();
accY = m_accelerometerY->GetAcceleration();
The accX and accY values are about 1.5 each when the board is at rest. Do we need to use SetZero? I tried putting in 1.5 for the value and then accX went to an entirely different non zero value, -2.5 or something like that. Can I just use AnalogChannel and do the scaling in the code?
Unread 02-02-2009, 12:47 PM
Re: Accelerometer class - isn't reading zero at rest?
You certainly can.
Before you do, be sure you are telling the class that your center point is 1.5V and your sensitivity is 300mV/g. I *think* the class assumes a different model.
Unread 02-02-2009, 02:09 PM
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
The classes aren't really documented.
How do you set the center point to 1.5V? How do you set the sensitivity to 300mV/g?
From what I can tell, the accelerometer class contains the function calls of SetZero() and SetSensitivity().
How do you use these?
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 02-02-2009, 05:11 PM
Jared Russell's Avatar
Taking a year (mostly) off
If you read the WPILib source code, it gives you some hints.
 * Set the accelerometer sensitivity.
 * This sets the sensitivity of the accelerometer used for calculating the acceleration.
 * The sensitivity varys by accelerometer model. There are constants defined for various models.
 * @param sensitivity The sensitivity of accelerometer in Volts per G.
void Accelerometer::SetSensitivity(float sensitivity)
	m_voltsPerG = sensitivity;
 * Set the voltage that corresponds to 0 G.
 * The zero G voltage varys by accelerometer model. There are constants defined for various models.
 * @param zero The zero G voltage.
void Accelerometer::SetZero(float zero)
	m_zeroGVoltage = zero;
So for the KoP accelerometer (zero G = 1.5V, sensitivity = 300mV/G), call:
myAccelerometer->SetZero(1.5);
myAccelerometer->SetSensitivity(0.3);
Floating point math zero flippo Programming 3 02-09-2007 09:00 AM
OI and analog: Zero value Astronouth7303 Programming 1 02-02-2004 04:00 PM
Community Zero archiver 2001 1 06-24-2002 04:08 AM
How about zero qualifying points? archiver 2000 0 06-23-2002 10:01 PM
Zero Hour archiver 2000 4 06-23-2002 09:59 PM
