Go to Post Please don't complain about the party that was thrown in your honor because they didn't use your favorite color of balloons. - Taylor [more]
Unread 02-02-2009, 17:38
Re: Suddenly disabled?!?
There are a few things that can cause these symptoms.
What does the Driver Station battery: status say? No Comms or No Code?
It sounds like the DS might be displaying No Code.
Unread 02-02-2009, 18:46
Mr. E Mr. E is offline
Its physics or stamp collecting
FRC #1883
Mr. E is an unknown quantity at this point
It says No Comms. Should it not be saying either?
Unread 02-02-2009, 20:43
No Comms means that it isn't a code problem at all.
The Driver Station and cRIO cannot establish normal communications, so the cRIO isn't allowing your code to execute.
Try running the Pinger utility on your PC to see what it can see.
Unread 02-02-2009, 21:46
bomber7 bomber7 is offline
Humanoid
FRC #0585
bomber7 is an unknown quantity at this point
(I use windriver)
Untrue, I have often gotten "No Comms" with a code error. (Instead of saying "No Code")
(All values are approx)
What I have noticied about the debug light:
You start your robot at 00s
10s Light turns on and is blinking
40s dashboard/Driverstation responds
40s Light blinking slows down
80s Light goes solid, robot begins operating
Previously I've messed up a define in such a way I attempted to use an undefined variable in the init of the robot. At 80s the robot light would turn off and the driverstation/dashboard would report No Comms.
The robot would then proceed to restart continously always coming online for a period of a few seconds before resulting in No Comms. It would always report No Comms with the light blinking slowly.
I've also had this problem when I tried to send too many tcp/ip packets at once. (Turns out trying to send 100 packets in less than a second blows up the cRIO =P)
Unread 02-02-2009, 23:02
Originally Posted by bomber7 View Post
...The robot would then proceed to restart continously always coming online for a period of a few seconds before resulting in No Comms. It would always report No Comms with the light blinking slowly.
You have the most interesting errors
Unread 03-02-2009, 05:23
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
I had a problem today where the DS and Dashboard showed enabled, but the DSC was showing a slow blink (disabled). It turns out that if your are using the camera and it is powered off or there is an comm problem, the DSC will be disabled. This happens while running also. A camera power or comm problem during a match will disable the robot. At least when it is started using the run arrow. I didn't have time to build and deploy a startup version to check that mode.
Unread 03-02-2009, 13:59
FRC #1883
I'll try pinging the computer today after school. I'm almost positive that its a watchdog issue which means there's a connectivity problem or its not getting fed properly. I know how to test and trouble shoot for connectivity. How do I feed the watchdog? Reading the manual and other forums simply say that it has to be done. I know that its basically receiving a signal from other devices. How do I "feed it more?"
Unread 03-02-2009, 14:06
Does this help? http://decibel.ni.com/content/docs/DOC-2957
Unread 04-02-2009, 09:48
FRC #1883
Yes and no....I've just about memorized the status light and we pretty much have a watchdog issue.
Unread 04-02-2009, 09:56
Lots and lots of ways to mess up that Watchdog.
Which development environment (Wind River or LabVIEW)?
What did you start from as a base (Advanced/Basic Framework, Simple Robot Template).
If you want to post a zip of your project, a second set of eyes will help.
Regardless of Bomber7's self-denial-of-service attacks against himself , the DS No Comms still bothers me as a failed Watchdog would produce a DS No Code error.
No Comms essentially means the DS Linux operating system cannot communicate with the cRIO VxWorks operating system. It should be outside our code unless we discover creative ways to crash the cRIO operating system.
Unread 05-02-2009, 12:01
FRC #1883
Well, I fixed the problem by setting everything back to "factory specs." Reimaged the cRio, reinstalled update 3.0 for labview, even reupdated the firmware for the DS. I think its the reimaged cRio that actually fixed the solution. We'll have to build our code a little bit more carefully this time (smaller incremental steps) to trouble shoot what kind of changes tick my watchdog off.
Disabled Question Mtg Ruler Rules/Strategy 6 05-01-2009 15:06
Different "Cam Suddenly Stops" Problem JohnC Programming 10 30-01-2007 21:37
Compiling problem - suddenly Glabals.o is missing C-*P*-B Programming 3 20-01-2007 08:03
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Disabled? Ryan F. General Forum 5 29-03-2004 18:03
