Go to Post This is ChiefDelphi. There are threads on everything! - LauraN [more]
Unread 31-01-2009, 14:03
warbots620 warbots620 is offline
FRC #0620
warbots620 is an unknown quantity at this point
Programming Compressor
The pneumatics and compressor are all hooked up, and the solenoid and compressor are hooked up and run with the basic code previded in labview, but it starts then stops and then starts again, and repeats that process many times.
Unread 31-01-2009, 19:24
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Re: Programming Compressor
make sure your opens and closes for the compressor aren't inside loops. if they are it will open and close the signal for the compressor repeatedly.
Unread 02-02-2009, 17:45
FRC #0620
the start and stop are not inside loops and the starting and stopping are random and very in length.
Unread 02-02-2009, 18:01
The compressor should be responding to the pressure switch. Can you watch the 120 psi pressure gauge while the compressor is cycling. The compressor should turn on when the pressure is below approximately 95 PSI and turn off when it reaches 120psi. If you have a leak in your pneumatic system, it could be cycling in that way.
Unread 02-02-2009, 18:26
FRC #0620
there is no leak, the spike relay just randomly goes on and off instead of staying on till it reaches its max.
This is the program:
Name:	Solenoid with compressor program.jpg
Unread 02-02-2009, 18:40
FRC #0620
We found our problem. We misconnected a wire to the pressure switch so instead of signal and ground we had power and ground.
Unread 02-02-2009, 19:37
gaby1367 gaby1367 is offline
Driver (Ret.)
AKA: Pablo
FRC #0714
gaby1367 is an unknown quantity at this point
another problem could be that you set the compressor loop to run every 100 miliseconds make it run until doner and then reset by adding a condition
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
compressor Greg Needel General Forum 2 14-02-2003 07:50
Compressor TwoEdge47 Pneumatics 5 04-02-2003 22:41
programming the compressor archiver 2001 4 23-06-2002 23:19
Compressor agenova Programming 4 22-02-2002 21:44
