Go to Post I think that's what they think you will think, therefore you are thinking what they want you to think. - Wetzel [more]
Unread 02-02-2009, 18:24
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Compressor NOT Working (multiple trials already)
It was tough to tell from your last post if you were aware fo this or not so I will post it anyway.
It is recommended (and allowed by rule R59-F) to replace the fuse in the Spike relay powering the compressor with a 20-Amp Snap Action breaker like the ones used for the PD board.
The compressor can draw significantly more than 20 amps when starting up which would cause a fuse to blow. The breakers are designed to handle significantly more than the rated capacity for short durations so they will not trip on compressor startup.
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Camera not working st1nkm4n Programming 0 31-01-2006 19:23
cam not working :( magical hands Programming 3 05-02-2005 21:45
