Go to Post Let's see some love for these fine people. Let's give it up for the refs. - Andy Baker [more]
Unread 02-02-2009, 19:03
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Camera Slowing code down?
So, i have the camera running the following code:
if(FindColor(GREEN, &par)){
printf("Particle Found");
Fairly simple, and works. however running this causes the code to slow down to around 1 execution every 3 seconds. (obviously Incredibly slow)
Im Using the IterativeRobot class to run the robot
yes, i have started the camera task.
the robot is running v11 of the CRIO image, and WPI is 3.0
I've tried:
Running the camera in a seperate task
- this causes the camera tasks to run at full speed, but the rest of the robot code runs at the incredibly slow speed.
let me know any ideas of whats going wrong
Unread 02-02-2009, 19:09
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Re: Camera Slowing code down?
We are having similar issues. http://www.chiefdelphi.com/forums/sh...ad.php?t=73447
The first thing you should try is dropping the camera image to 160x120 pixels. That should speed it up a bit, but its still dreadfully slow.
Unread 02-02-2009, 19:11
Maxpower57's Avatar
Fabuloso
AKA: Maxwell V.
Thats already the resolution.
i fear i may have to create a new task for the rest of the robot code as well,
but then it may be faster to just use the SimpleRobot class.
anybody have any other ideas?
Unread 02-02-2009, 20:00
Maxpower57's Avatar
Fabuloso
AKA: Maxwell V.
Ok I got it.
When the documentation says the Wait(5); function waits for 5 milliseconds, it means seconds. (this happens with the timer->Get() too btw) take out this line.
ah, thank you wpilib.
Unread 02-02-2009, 20:57
Originally Posted by Maxpower57 View Post
Ok I got it.
Update 2 changed the default to seconds (and was noted in the release notes). Looking at the documentation from C++ update 3, I don't see any references to milliseconds. If you are looking at the latest documentation and see something that is wrong, you should post on the FIRST forums so that it can be corrected.
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Slowing down Camera drive turning Zalumaskov Programming 1 27-02-2005 10:11
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Slowing Down Drive Motors Arc736UV Programming 5 24-01-2005 22:35
Is FIRST slowing down with it's updates! mtaman02 Regional Competitions 8 15-03-2004 23:25
