Re: FP Gearbox: Last stage gear?
You can try measuring the diameter and counting the number teeth, you should be able to look up the pitch on a table at that point. I haven't opened the new fisher prices so I don't know off the top of my head.
Well, I gave it another shot, and the best I could measure the very last gear (38 teeth, with the extended plastic) is 2.25 module, 20 degrees pressure angle (nearly perfect match). The 12 tooth gear, the one I was interested in, does not appear to be the same, by a good margin, which is obviously very weird.
Since I'm not a gear expert, not even a mechanical guy, I'll leave this one for the MEs out there. For our application, close enough was more than we needed, so we just drew the gear profile "by eye", machined it on our home-made CNC mill, measured, and iterated - only took two shots! ![]() |
Quick question I wanted to cnc gears on my cnc but what tools or bits would I need to get the job done?
Thanks in advance. |
That will depend on the size of the gear and the material. The smaller the teeth, the smaller the cutter, I assume.
Normally this requires an involute gear cutter(or hob), of which there will be several for the same Diametrical Pitch value, as the profile of the cutter needs to change a bit due to the number of teeth. You can also grind a peice of tool steel to make a form tool and use it as a single point cutter. OR if the tooth profile is large enough, you can use a properly sized end mill to cut the gear on a 3 axis mill. However this would likely be a very hard thing to accomplish(in something other than plastic / wood), for reasons I wont go into here. So, if you have a 4 axis CNC or a manual mill with a dividing head, or rotary table look into the involute gear cutters.
If you want to search around some, another word for gear cutting is hobbing. Here is one example http://www.youtube.com/watch?v=VHTXa...eature=related and here is another, using a different style cutter http://www.youtube.com/watch?v=62yme...eature=related Last edited by Justin Stiltner : 04-02-2009 at 16:15. |
| AM Planetary Gearbox (removing the fisher price gear/buying one without a gear) | Ice Berg | General Forum | 10 | 04-02-2009 15:43 |
| Last Year's Gear Ratio | AndyB | Technical Discussion | 4 | 11-11-2007 01:17 |
| BaneBots 56mm Gearbox - Second Stage Sun Seizing | Gary Bonner | Motors | 18 | 10-02-2007 12:52 |
| Last year's gearbox | MishraArtificer | General Forum | 3 | 10-01-2007 10:57 |
| Worm Gear Gearbox | dddriveman | Technical Discussion | 38 | 07-01-2005 14:43 |
