Go to Post Wishes and dreams can hold a robot together just as well as nuts and bolts. - Kyle [more]
Unread 31-12-2008, 19:28
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Wink Save you a heart attack!
Ok, so i was in the shop the other day setting up computers, and one of my friends was driving our bot with the transplanted system in it when all of a sudden is stopped working, I saw that the bot still had power, so i figured the battery must too low to move the bot around, so i swapped out the battery and it still didnt work. I took a closer look at the panel and noticed the cRio did not have any power, even though the Distribution panel said it had output to the 24v, but not to the camera...I was not too worried about the camera, but i thought the cRio may have been shot! None of the led's were lighting up, and the board said it should have power. I pulled out the connectors, rewired them, and it still did not work. Thats when i started stressting out! anyways it turns out that the battery that i had put in was only registering 4.6v...which was pretty strange, considering it was from '08.
anyways long story short...If your cRio does not power up, even though the Power Distribution board says it has power, check your battery. Also, the camera may be the first to not get power from the board with a really low battery!
Unread 31-12-2008, 19:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Save you a heart attack!
Some 2008 batteries have been known to have some issues.
See this thread for more info
Unread 31-12-2008, 20:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The camera 5V light is only going to tell you is your power is below 5V. Or at least, below a little above 5V. The camera power supply is what's known as a "buck" power supply, meaning it reduces some variable higher voltage (~12V) to some stable lower voltage (5V). It's not capable of increasing voltages, so it will stop working when the battery drops below 5V.
The 24V power supply is a "boost" power supply, meaning it increases some variable lower voltage (~12V) to a stable higher voltage (24V). It will keep the 24V stable over a considerable range of input voltages, but it can't work miracles. Or, at least, it has to be designed with some minimal constraints in mind. So if your voltage drops below (I think) 6-7V, then it will stop working. However, that's much lower than the tolerance of the IFI controllers, which is why we're not using backup batteries this year. Plus, if your battery gets that low, it's not going to be operating any motors anyways.
Unread 02-01-2009, 13:01
Racer26 Racer26 is offline
I experienced this EXACT phenomenon (24V cRIO light on, but cRIO off, and 5v Cam light off) on the 31st with a 2008 battery.
Unread 02-01-2009, 15:43
I have it on good authority that the 24 volt voltage convertor that is intended to power the CRIO stops functioning when the input voltage is 4.5 volts or less. Make that 5 or 6 volts to be sure and you should be alright. A dead battery could register a very low terminal voltage under load and then return to 12 volts with no load on the battery. That is why, I don't recommend using a voltmeter to check for battery charge condition.
Unread 14-01-2009, 17:12
PlaidPillagers's Avatar
PlaidPillagers PlaidPillagers is offline
FRC #2538 (Plaid Pillagers)
PlaidPillagers is an unknown quantity at this point
Question Re: Save you a heart attack!
Our cRIO shows similar symptoms as those previously mentioned, however our problem is not remedied by replacing the battery. Everything was hooked up normally, but it spontaneously failed.
We know that the cRIO was supplied with ample power. When we try to set up the electrical system, everything but the cRIO powers up. We believe that the problem resides within the cRIO. Where do we send it to get it fixed or replaced?
Team 2538
Plaid Pillagers
Morris, Minnesota
Rookie Year 2008
Unread 29-01-2009, 13:09
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
ours has the same issue; the crio simply stopped functioning. it's not the voltage; we tested the 2a fuse that is soldered to the board inside the chassis and it is blown. We NEED to replace the crio!! Any ideas who we call?
Unread 29-01-2009, 13:21
To be sure...You opened the CRIO and tested the internal fuse?
Unread 29-01-2009, 13:30
1-866-511-6285
Unread 02-02-2009, 21:36
skidmarks skidmarks is offline
FRC #0957 (WATSON)
skidmarks is an unknown quantity at this point
Out team had the control system on the bench, doing some tests. We had five motor controllers hooked up (our sixth one was removed) and two were attached to motors. Since it was not entirely set up (no analog breakouts or other important pieces plugged int), we didn't have a battery voltage readout on the DS. When I went to program it, only one of the two (small) motors would run. The other simply wouldn't run. We switched the motors around, used different PWM outputs and speed controllers, but still couldn't get the motors to run. A while later, the DS lost communication with the cRio. We noticed all the lights flickering on the various components (partially synchronized, partially chaotic). After shutting it off, we took a multimeter to our battery terminals (still connected to the breaker), and thought something was wrong with our reading. We were only getting a little over 3 volts. When we disconnected it and tested the battery alone, we also got a little over 3 volts. After getting a new multimeter (neither of us could believe it would even power on with 3 volts), we tested again. It was a little over 3 volts. We replaced the battery with one right off the charger (we tested it and it had over 12 volts) and the system worked fine. We realized noone had replaced the battery in several days of use. Moral of the story: next time we should check the battery voltage.
Unread 03-02-2009, 07:32
I think it is important to add a little info here. If you run your batteries down to 3 volts (or a voltage that will not power the CRIO) it is possible that some chargers may not begin a charge cycle. Smart chargers may see that condition as you trying to hook up a 6 volt battery or something even less. Establish some method of getting batteries on the charger at regular intervals in your build and test season. Also, do not try to charge batteries that are warm to the touch. Wait an hour, just like swimming and eating.
Unread 03-02-2009, 07:53
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
you know reading down the portal topics list these days sounds like Web Md...
"Save You a Heart Attack"
"Trying to Lose Weight"
"Suddenly Disabled"
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 03-02-2009, 11:04
mrnoble's Avatar
teacher/coach
The wonderful people at National Instruments were very responsive when we called to describe our problem. We had a replacement cRIO the next day. Thank you NI!!
pic: Brandon heart auto henryBsick Extra Discussion 18 03-03-2010 10:38
Save the Gearbox, Save the Game Mark_Benedict Motors 18 21-02-2007 09:25
Heart messages AcesPease Chit-Chat 2 15-02-2007 16:08
Teammate Heart Transplant Mark McLeod Chit-Chat 7 19-09-2006 07:30
having a heart attack... AHH! archiver 2000 4 24-06-2002 00:30
