Go to Post It means Dave Lavery isn't on the Game Design Committee this year. If he were, you probably would have found a banana instead. - Alan Anderson [more]
Unread 02-02-2009, 22:05
PHSRobotics PHSRobotics is offline
FRC #2135
PHSRobotics is an unknown quantity at this point
Smile Shooter Question
ok so we're having a problem with our software for this shooter that erin's brother decided that we needed. we keep getting an error message. Error 1004 the vi is attached.
Unread 03-02-2009, 20:41
Tt321b Tt321b is offline
AKA: Tony
FRC #1803
Tt321b is a jewel in the roughTt321b is a jewel in the roughTt321b is a jewel in the rough
Send a message via AIM to Tt321b
Re: Shooter Question
I am not sure of what you are trying to do. I looked up error 1004 and it said that it is because the VI could not be found. If you said what you are trying to do then I could try to help.
Team 1803
2006 SBPLI Regional
- Highest Seeded Rookie
- Rookie All-Star Award
2008 SBPLI Regional
- Regional Finalists (358, 533, 1803)
Unread 03-02-2009, 21:14
FRC #2135
Cool Re: Shooter Question
Well yes, we made the VI. LabVEIW said that there were no errors. Then we tried to run it and it showed that it had an error. We have two motors that control a lazy susan with a shooter mechanism on the end. Those two motors attatch to the joystick that control the left and right swivel and up and down motion. Then there is another motor to control the shooter wheel, which 'shoots' the moon rocks. We're feeding the watchdog. this is the error message that pops up when we try to highlight execution: Error 1004 occurred at Open VI Reference in NI_FPGA_Interface.lvlib:NIFPGA System.lvlib:Start Async Agent.vi->NI_FPGA_Interface.lvlib:NIFPGA System.lvlib:Get.vi->NI_FPGA_Interface.lvlib:NIFPGA DIO.lvlib:WritePWMPeriod.vi->DigitalModule.lvlib:Open.vi->PWM.lvlib:Open & Configure.vi->MotorControl.lvlib:Open Victor.vi->ShooterVI.vi
THANK YOU!
FRC #2135
THANK YOU!
Unread 03-02-2009, 22:27
AKA: Tony
FRC #1803
I have attached the changes I have made to your VI. Hopefully this works, I am saying that because I am new to labview (but not to programing) and I have yet to download any code to the robot (my team is way behind schedule). If someone else out there could double check to see if it is right would help. Hopefully this will solve that error too.
Team 1803
2006 SBPLI Regional
2008 SBPLI Regional
Unread 04-02-2009, 19:26
FRC #2135
THANK YOU SO MUCH! Ok now we are getting another error. Error -44085 occurred at Loaded FPGA has incorrect version or revision. Library expecting Version 2009, Revision 1.0.0. I will try and figure it out. Any ideas? THANKS AGAIN!!!
Unread 04-02-2009, 19:48
AKA: Tony
FRC #1803
Try redoing the VI because I don't have the update for Labview/CRio on my laptop so I did it with the old version and you probably have the newer version.
Team 1803
2006 SBPLI Regional
2008 SBPLI Regional
Unread 04-02-2009, 20:46
FRC #2135
Alright so I re-wrote it on the updated program. I got another error: Error -44085 occurred at Loaded FPGA has incorrect version or revision. Library expecting Version 2009, Revision 1.0.0. I am searching the FIRST website and Chief Delphi to figure it out.
Unread 04-02-2009, 20:51
p00rleno p00rleno is offline
Team Advisor & Former Team Leader
AKA: Andy
FRC #2590 (Nemesis)
p00rleno is on a distinguished road
That's the error I get when I try to "open" something that dosn't exist... are you actually plugged in where you say you are in the code?
Unread 04-02-2009, 21:47
FRC #2135
I'm not understanding your statement. We re-wrote the Vi on a blank Vi from an example. Could you explain what you're saying?
Unread 05-02-2009, 00:02
This error can happen if you accidentally try to run your robot program on your PC instead of on the cRIO. Make sure you're opening the .lvproj and not just the .vi file.
Unread 06-02-2009, 19:14
FRC #2135
Thank you we will fix that
pic: Shooter Dave Campbell Robot Showcase 6 17-02-2006 22:05
side shooter Korbin Robot Showcase 21 14-02-2006 17:23
Adjustable Shooter Nitroxextreme Technical Discussion 2 20-01-2006 19:33
Ball Shooter Squall Rules/Strategy 7 11-01-2005 14:47
Ball Shooter Squall Kit & Additional Hardware 0 11-01-2005 06:52
