Go to Post Then use Newton's handy-dandy 2nd law (Force = mass*acceleration) to solve... - Chris Hibner [more]
Unread 31-01-2009, 11:31
BrandonD-1528's Avatar
BrandonD-1528 BrandonD-1528 is offline
AKA: Brandon Dusseau
FRC #1528 (Monroe Trojan Robotics)
BrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the rough
G++ not found
While we were attempting to build our practice project with Wind River, we got the following error:
C:\DOCUME~1\Team\LOCALS~1\Temp\make3765.sh: g++: command not found
C:\WindRiver\workbench-3.0\x86-win32\bin\make.exe: *** [Tank_Drive/Debug/Objects/Tank_Drive/drive.o] Error 127
Build Failed in Project 'Tank_Drive' (Process Exit Value was 2): 2009-01-31 10:42:56 (Elapsed Time: 00:02)
We downloaded MinGW and Wind River still refuses to find G++. Are there any settings we need to configure to find it? Any help is appreciated.
Brandon Dusseau (website)
Monroe Trojan Robotics mentor
Software Engineer
Michigan Tech alumnus
Unread 02-02-2009, 22:13
Jared Russell's Avatar
Taking a year (mostly) off
Re: G++ not found
Make sure g++ is in your PATH environment variable maybe?
Unread 03-02-2009, 00:33
s0crates s0crates is offline
s0crates is on a distinguished road
Re: G++ not found
learned this the hard way, but xp doesnt update PATH etc until after a reboot. Even if it looks like it was changed. That appears to have been fixed in vista - I was recently needing to let gimp know where ghostscript was through a sys var and I didnt need to reboot unfortunately thats not so in xp.
-jonathan
Unread 03-02-2009, 14:59
Re: G++ not found
We tried rebooting many times with no luck. I don't remember if we mentioned this before, but we installed G++ with MinGW. I'm not sure what difference that makes.
Software Engineer
Unread 03-02-2009, 15:13
Re: G++ not found
I second Abwehr - is the g++ folder in PATH? If you type
echo %PATH%
into cmd you can see whats in it...
-jonathan
Unread 03-02-2009, 15:36
Re: G++ not found
Thank you
Software Engineer
Nirio_device_open not found. teshazman NI LabVIEW 1 17-01-2009 21:00
CMUCam2.llb not found Amin LabView and Data Acquisition 1 21-01-2006 18:31
Camera not found! SpeakerSilenced Programming 0 21-02-2005 12:54
Camera not found!!! Code\\Pilot Programming 11 02-02-2005 00:04
Header Not Found (adc.h) NotQuiteFree Programming 2 23-01-2004 16:26
