Go to Post A coin flip is a wonderful thing. Not because it makes the decision for you, but because when the coin is in the air, you realize what you really want. - rtfgnow [more]
Unread 02-02-2009, 22:39
program1's Avatar
program1 program1 is offline
AKA: RJ
FRC #2441
program1 will become famous soon enough
Run works but build&deploy doesn't
we got drive code to work and everything, then we added in the compressor and a single solenoid.
when we use the "temporary" run function, the compressor turns on and we can make the actuator go.
when we use the build & deploy, then reboot, then enable, only our motors work, but our compressor and solenoid doesnt work!
are we missing a step somewhere?
ok, who ate my hot pocket?
LabVIEW Woes: Build/Deploy time too long?! leftylink NI LabVIEW 7 27-01-2009 21:52
Cam works but RC won't LightWaves1636 Programming 9 03-02-2006 13:15
OI PWM Lights blink red but still works? SpeakerSilenced Programming 4 21-02-2005 10:44
Q&A Discuss: But it's boring stuff... CD47-Bot Extra Discussion 2 15-12-2002 22:44
