Go to Post the few, the proud, the animators. - BuddyB309 [more]
Unread 02-02-2009, 22:39
program1's Avatar
program1 program1 is offline
AKA: RJ
FRC #2441
program1 will become famous soon enough
Run works but build&deploy doesn't
we got drive code to work and everything, then we added in the compressor and a single solenoid.
when we use the "temporary" run function, the compressor turns on and we can make the actuator go.
when we use the build & deploy, then reboot, then enable, only our motors work, but our compressor and solenoid doesnt work!
are we missing a step somewhere?
ok, who ate my hot pocket?
Unread 02-02-2009, 22:41
Re: Run works but build&deploy doesn't
Be sure to mark as Run at startup, otherwise your code is deployed waiting for something to call it. Personally I wish we'd been able to make it fewer steps or simpler for FRC, but you are almost there.
Greg McKaskle
Unread 03-02-2009, 20:21
program1's Avatar
AKA: RJ
FRC #2441
Yes, we are building, then running as startup. then, only our motors work...the compressor and solenoid do not turn on....
but when we try again with the temporary run, everything works!
-note: we get this message right after we press run as startup:
we then press ok anyways and then proceed with loading on the code. but then, all the buttons get swithced up !
Unread 03-02-2009, 22:32
program1's Avatar
AKA: RJ
FRC #2441
update: we proceed with building and running as start up...
our motors work, our compressor works, and one solenoid works (but the joystick button gets changed to something else!), and our other solenoid doesnt respond at all.
---when we just use the temporary run deploy, our motors, compressor, and both solenoids works perfectly, though!!!
(note, our second solenoid is a smc double solenoid.....we treated this just as two separate single solenoids, putting one on solenoid channel2 and the other on 3........again, everything works using run, but we get problems when we use build and run as startup)...
LabVIEW Woes: Build/Deploy time too long?! leftylink NI LabVIEW 7 27-01-2009 21:52
Cam works but RC won't LightWaves1636 Programming 9 03-02-2006 13:15
OI PWM Lights blink red but still works? SpeakerSilenced Programming 4 21-02-2005 10:44
Q&A Discuss: But it's boring stuff... CD47-Bot Extra Discussion 2 15-12-2002 22:44
