Go to Post It's funny how many things learnt in Physics class at school I am able to apply to FRC. - pilleya [more]
Unread 02-02-2009, 22:43
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
Re: Toggling boolean using 2 limit switches
i can help make the VI for you or show you at least how it should be done but i need to know which limit switch you want to use to make the value positive. its complicated because i don't know if the value is, say 1, or if its a changing value. generally if its a motor you can use either selectors or multiple Case structures to choose your value.
[edit] i've made a simple series of cases here that should help you along. if you still can't figure it out, i'll be back on between 3-4 or 9ish
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Limit switches(in C++) beefy1 Programming 3 24-12-2008 15:27
Using Limit Switches with the Arm iwin2000 Programming 3 18-02-2008 03:52
Limit Switches ChrisR_522 Programming 2 25-01-2008 08:04
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Limit switches Team168 Programming 8 10-02-2003 16:22
