using digital inputs from the driver station
I'm not sure exactly how to utilize them.
I know that the Driver Station Get dig In samples all of the digital inputs.... but do you have to insert the values into an array before you can see if a certain switch hooked up to the driver station is sending true or false, and if so... how do you do that? Basically, I am trying to have a switch on the driver station return true or false, but I have found that u can't wire the Driver Station GetDig In directly to a conditional. Any help would be greatly appreciated. Thanks. |
| Programming Digital Inputs from Driver Station | spooncwru | Programming | 8 | 01-02-2009 13:14 |
| LabVIEW - Analog inputs from driver station lag? | RedOctober45 | NI LabVIEW | 1 | 30-01-2009 10:39 |
| Digital Outputs on the Driver Station with C/C++ | Bongle | C/C++ | 6 | 26-01-2009 15:45 |
| Using driver station digital inputs | Japper | FRC Control System | 6 | 19-01-2009 20:01 |
| Using Analog Inputs as Digital (on the OI) | Guy Davidson | Control System | 16 | 10-03-2008 17:17 |
