Go to Post If you can't be bothered to read the Q&A, why are you spending thousands of dollars competing? - Ian Curtis [more]
Unread 03-02-2009, 09:17
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Re: multi-pin connectors
I noticed a few of the last posts seem to be recommending the 45AMP contacts. Over at PowerWerx and other sites, they're saying 45AMP contacts should be used on 10AWG wire. We were planning to use 12AWG to wire the Jaguars and motors, etc. Thus, a few questions:
Since we only have 12AWG right now, is that safe and legal for the motors, etc? From what I've read in the rules, I'd say yes.
Will the 45AMP contacts crimp down far enough to safely grab the 12AWG, if they're designed for 10AWG? From what I know of wiring, there's not too much of a size difference there.
Unread 03-02-2009, 09:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The datasheet from Anderson
http://www.andersonpower.com/litlib/...ml/download/62
shows that the 45 amp contacts are designed to be used with 14 thru 10 gage wire.
Unread 03-02-2009, 09:26
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Well, so it does. That answers all the questions then, I guess. Consider us converted. We shall use Anderson power poles.
Multi Pin Connectors TonzOFun Electrical 2 05-02-2006 01:00
Multi-pin Connectors Adam Shapiro Electrical 9 29-01-2004 14:26
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
