Go to Post In the end, you get out of FIRST what you put in. - BlueLipstick [more]
Unread 02-02-2009, 17:28
darty darty is offline
None #0204
darty is an unknown quantity at this point
Mysterious error message
Title says it all. We're using 8.5 LABView and cRIO image 11. We don't know if we have the most up to date WPI library because we don't know how to check how up to date it is, so that may be the problem (even if its not, if you can tell us how to check that anyway, that'd be great thanks.)
The screenshot of the error is atached.
Unread 02-02-2009, 17:35
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
Re: Mysterious error message
try re-flashing the system. Be sure to do a full power-down and power up of the cRio afterwards and see if it persists. Let us know.
Unread 02-02-2009, 19:14
Pumagrif's Avatar
Pumagrif Pumagrif is offline
Crazy 204 Mentor
AKA: Geoff
FRC #0204 (Eastern Robotic Vikings)
Pumagrif is an unknown quantity at this point
We did re-flash the the cRIO and the and did a complete power down. Then powered it back up and the same problem persists.
For a successful technology, reality must take precedence over public relations, for Nature cannot be fooled.
Unread 02-02-2009, 20:13
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
A general cause of strange error messages is that you have re-imaged the cRIO with a newer image without also updating the PC software as well.
I'm familiar with this in WindRiver and not LabVIEW, so YMMV.
Unread 02-02-2009, 20:28
Are you switching between windriver and LabVIEW? I'm wondering if a C++ program is still running.
You can verify the LabVIEW version by going to Help->About FIRST Robotics Competition Software.
See the following post on the FIRST forums for different ways to verify the image version: http://forums.usfirst.org/showthread.php?t=10811 I think the FRC Diagnostic Tool might do it too.
Unread 03-02-2009, 10:38
Pumagrif's Avatar
Crazy 204 Mentor
AKA: Geoff
We have the latest version of labview and the cRIO image. WindRiver has not been installed at all on the computer. We download the separated files on the WPI website.
Unread 03-02-2009, 13:38
If you are using LabVIEW and not using windriver, why did you download files from WPI?
Can you describe everything you downloaded, what you installed (and in what order) and what you uploaded to the cRIO, etc.
As this is a fairly esoteric error, you would probably get a better response on the FIRST control system forums or the NI FIRST community. However, they'll probably want to know the same information.
Camera error message Slick NI LabVIEW 1 25-01-2009 11:34
What is this error message? chantilly_team Programming 3 22-01-2005 10:09
message too short error Melissa Nute CD Forum Support 7 03-06-2004 00:02
hexidecimal error message in notepad Anthony Kesich Programming 6 09-02-2004 18:42
Error Message Obi Programming 4 24-01-2004 20:10
