Go to Post Please look around the forum, I believe this clue is already under discussion and has been overly dissected. - ttldomination [more]
Unread 08-01-2009, 14:42
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Conveyor Belt
Anybody know how to go about shortening and reataching a treadmill belt??
Thanks
Bruce
Unread 09-01-2009, 10:05
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
Re: Conveyor Belt
Originally Posted by squirrel View Post
We're planning on being able to pick up two balls at once, and feed them into a screw lift. This design details are still vaporware
The screw lift does take up a lot of room, but most of that room is used to store balls, so it's not wasted.
Ah, the designs my former team has produced for a screw type lift only accommodate one ball. What are you planning on driving it with?
Unread 12-01-2009, 18:52
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Re: Conveyor Belt
anyone have any pictures of a ball lift mechanism?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 12-01-2009, 23:23
lingomaniac88 lingomaniac88 is offline
FRC #1554
lingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud of
Re: Conveyor Belt
I know that in 2006, my team used a conveyor belt to bring the balls up to a launcher. We used a conveyor belt at the top and guide rails at the bottom. I heard that it worked very well.
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all, try something."
-- Franklin Delano Roosevelt.
Unread 13-01-2009, 10:17
nevereverregret's Avatar
nevereverregret nevereverregret is offline
AKA: sammy
FRC #2869 (One Small Step)
Team Role: Student
nevereverregret will become famous soon enough
Send a message via AIM to nevereverregret
Re: Conveyor Belt
Originally Posted by Lowfategg View Post
I have also heard of teams using round belting.
Im confused on how you would do this
"How do you join.
You show up.
How do you get responsibility.
You take responsibility."
Unread 13-01-2009, 10:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Conveyor Belt
The screw is VERY large! and it's not the part that turns.
Our web page has some pictures of the prototype.
Unread 13-01-2009, 11:12
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
Re: Conveyor Belt
Any suggestions on fattening up the center of a PVC pipe to drive a belt?
We intend to use 2 1/2 ID PVC with guides on the way up, aprox 30" long total. The alignment issue is controlled by two eyebolts at the top and a very rigid frame.
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
Unread 13-01-2009, 15:24
MrForbes's Avatar
AKA: Jim
Re: Conveyor Belt
Maybe you could thin down the edges instead? run the motor that drives the pipe, and hold a file on it. Should only take a day or two to get the profile you want
Or if you can find thin sheet PVC material you could glue on strips of it.
Unread 13-01-2009, 18:12
Jedward45 Jedward45 is offline
FRC #2220
Jedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant future
Re: Conveyor Belt
There are certain materials that we have discovered to grip orbitballs extremely well..... (a little hint: bedroom would be incomplete without a dresser that can hold clothes in place....) My advice if you cant figure this out, is to bring an orbitball on a date to a hardware store an run it through any materials.
Unread 03-02-2009, 00:39
jmarsh24 jmarsh24 is offline
FRC #2085
jmarsh24 will become famous soon enough
Re: Conveyor Belt
Im looking for some urethane belting material and am trying to find a cost effective way of bonding the stuff. Anyone have any ideas?
Unread 03-02-2009, 11:10
Dick Linn's Avatar
no team (Synergy)
Re: Conveyor Belt
Does it need to be urethane, or would something like neoprene work? You might experiment with some Pliobond contact cement.
http://www.mcmaster.com/#conveyor-belts/=fxqrh
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 03-02-2009, 11:27
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Conveyor Belt
Check out this thread:
http://www.chiefdelphi.com/forums/sh...light=polycord
Unread 03-02-2009, 12:29
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Conveyor Belt
It's kinda funny how things work out.
In the last 3 weeks we've tried everything we read on these forums, and it was always one thing or another that went wrong. Finally, last night we came up with our own solution to this that hasn't been suggested on these forums. What we found left some black residue behind, so once we test 2 more materials that are coming in Thursday I'll post what we've done. I knew once I found this stuff when spelunking through TrueValue in Week 2 that we should have used it right away, but alas I'm not the only one on the team.
My tip: stay away from Lowe's and Home Depot when in a search of local hardware stores; they're too big and you'll spend way too much time looking for the right thing. Start with the mom and pop shops that are small and have everything closer together without all of the non-relevant items in between them. On top of that, usually you can touch/sample a material without opening an entire box. Then, once you have an idea of what you want, purchase the sample and test on the prototype.
GitHub
Unread 03-02-2009, 12:41
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Re: Conveyor Belt
Use the surgical tubing that came with the robotics kit! Its extremely light and effective...
We are trying to use the surgical tubing is there an easy way to connect the ends so that they don't come apart during competition?
Your answer is most appreciated!!
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 03-02-2009, 12:42
craigcd's Avatar
craigcd craigcd is offline
FRC #2221 (RoboDawgs)
craigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant future
Re: Conveyor Belt
We have used a conveyor belt material manufactured by Intralox. It comes in multiple widths and uses a variety of sprocket diameters.
http://www.intralox.com/
Conveyor Belt Setsanto 3D Animation and Competition 2 21-01-2008 20:51
conveyor belt materials? Salik Syed Technical Discussion 7 13-02-2006 14:51
Conveyor Belt Garth1388 Inventor 4 30-01-2006 13:33
COnveyor belt wheels sdcantrell56 Technical Discussion 4 18-01-2006 00:10
vertical conveyor belt ahecht Technical Discussion 3 15-02-2002 16:16
