Go to Post Glitter… lots of glitter. - Andrew Schreiber [more]
Unread 03-02-2009, 11:00
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
Question can we modified a piece
I want to modify the coupler, and make a hole in the center to pass an axis through the hole
can we make that???????
Unread 03-02-2009, 11:09
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: can we modified a piece
Are you talking about one of the window motor couplers? If so, then yes, you can modify the coupler in any way you want.
Unread 03-02-2009, 11:26
frcchile's Avatar
FRC #2576
thanks you
Unread 03-02-2009, 14:25
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
You'd be amazed at what we've done to these poor couplers in the past. The bottom line is that you're not modifying the motor, so all's fair.
"It's NOT Just A Robot Thing!"
modified toughbox gorrilla Technical Discussion 7 02-04-2008 17:13
Modified AndyMark Gearboxes Rob2713g Technical Discussion 4 18-02-2007 16:03
Where can we order the acme rod tri-mount plastic piece and rods? waialua359 Kit & Additional Hardware 1 10-02-2007 08:43
can motors be modified ronnie_82 Motors 37 07-01-2003 08:09
can motors be modified ronnie_82 Rules/Strategy 2 18-12-2002 13:26
