Go to Post Messy wires are a pain in the chassis - [more]
Unread 03-02-2009, 16:03
Lilszamora's Avatar
Lilszamora Lilszamora is offline
Computer Consultant
AKA: Sammy
FRC #0393 (Full Metal Jackets)
Team Role: Animator
Lilszamora is an unknown quantity at this point
Send a message via AIM to Lilszamora Send a message via MSN to Lilszamora Send a message via Yahoo to Lilszamora
Can't change team # (was: Driver Station problem)
Our driver station won't let us change our team number when we hold down the down arrow.
Any help would be appreciated.
Unread 03-02-2009, 16:18
Re: Can't change team # (was: Driver Station problem)
What software revision does the Driver Station screen display?
If you see the letters "OTB", you're still running the Out of The Box firmware, which does not implement the ability to set the team number. You'll need to update both the Driver Station and the cRIO, using the procedures found in the Control System Manual (http://www.usfirst.org/frccontrolsystem).
Unread 03-02-2009, 16:26
Lilszamora's Avatar
Computer Consultant
AKA: Sammy
Team Role: Animator
ok thanks, that explains a lot, it still is OTB, because we don't have internet at our meeting place. but I downloaded the update today so then we will be able to get it then, thanks you so much.
Driver station problem team2491 FRC Control System 7 31-01-2009 00:18
Problem Downloading Program from WindRiver to Driver Station The_Laughing_ManMII C/C++ 10 09-01-2009 20:03
Driver Station not allowing team number change Bryan Herbst FRC Control System 2 04-01-2009 12:26
Driver Station Blank Screen, Anyone have the same problem? LDavies562 FRC Control System 14 22-12-2008 19:34
bug: Can't change team number to Team 0 Joe Ross CD Forum Support 1 18-12-2003 09:52
