Go to Post We call ourselves community/family. We are. Our kitchen table where we gather is the size of Chief Delphi. - JaneYoung [more]
Unread 03-02-2009, 16:04
alaa abo alheja's Avatar
alaa abo alheja alaa abo alheja is offline
FRC #1946 (Mishka Monsters)
alaa abo alheja is an unknown quantity at this point
Send a message via MSN to alaa abo alheja
Wink need help with gyro sensor connection
this year my team decide to use the gyro sensor for the first time,i have some questions about the gyro connection:
1-how much voltages it needs?
2-how we connect it(some pics To clarify if it available)?
team#1946
thank you for anyone will help me
Unread 03-02-2009, 16:25
Re: need help with gyro sensor connection
It needs 5 volts, which is supplied by the analog breakout board.
Connect it to an analog input using a servo extension cable (usually called a "PWM cable" around these parts). The white signal wire goes to the hole next to the word "Rate", the red power wire goes to the center hole adjacent to it, and the black ground wire goes to the third hole at the corner of the board. You can also connect the "Temp" signal the same way to another analog input if you want to be able to calibrate the gyro response based on ambient temperature.
The 2009 Sensor Manual should tell you this explicitly, but it doesn't. (You should still read it; find it under Section 8 - The Robot on the Competition Manual and Related Documents page.)
Unread 03-02-2009, 16:47
first thank you for ur help
we use only one pwm cable for it?
Unread 03-02-2009, 23:48
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
You need 1 pwm for your rate output and 1 pwm for your temp output. They're seperate circuits, so you can't run 5v to the rate side and get a temp output
Get yer robot source code here!
Unread 04-02-2009, 08:46
Question Re: need help with gyro sensor connection
thank u for ur help.......
u said we need two pwm cables the first to the analog input
where we have to connect the scand pwm cable?
Unread 04-02-2009, 11:03
Hacker
Basically, your gyro's i/o should look something like this
Rate o o o
Tempo o o
Each circuit needs a signal output, a 5v input, and a ground. So you wire up the PWMs parallel to the rate/temp labels.
Unread 05-02-2009, 10:03
thx for ur help
can anyone put a pic of the gyro with the pwm cable connections ?
the second thing we have the second pwm cable from temp 000 where i have to connect it?
team#1946
Unread 05-02-2009, 11:59
See my post #2 in this thread.
Unread 31-08-2009, 04:52
Sasals's Avatar
Sasals Sasals is offline
Sasals is an unknown quantity at this point
Tswift
Guess what? I replaced the sensor and all works perfectly. I wanted to thank you for all your help. I really appreciate it
cline hho
Help With Gyro Bronson Electrical 3 10-01-2008 21:09
Need help with gyro turn magical hands Programming 2 11-03-2007 21:53
Need help with Gyro = Analog Devices ADXRS150EB Jack Jones Technical Discussion 9 18-07-2005 07:00
With gyro need to access ADC for poteniometer mrozek Programming 0 21-02-2005 13:39
Need help with Sensor Hop_of_752 Programming 5 06-02-2004 23:43
