Go to Post Facebook for FIRST already exists. It's called Facebook :) - dcarr [more]
Unread 03-02-2009, 16:57
saaby's Avatar
saaby saaby is offline
AKA: Taylor Cannon
FTC #0127 (Fighting Pickles)
saaby can only hope to improve
[FTC]: Autonomous
At my team's first competition nobodies autonomous code seemed to work. We believe the field managment system was at fault. Our code worked when we ran it on the field managment system we downloaed. Anyone have something similar happen? If not could someone possibly post their autonomous code or at least something that worked at competition for them?
Unread 03-02-2009, 19:42
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
Re: [FTC]: Autonomous
I have a couple of questions:
1. Did your team use the latest software templates from the www.ftctraining.com web site?
2. Did your team start the autonomous program running on the NXT after it was placed on the playing field?
3. Did the robot behave as expected during the tele-op portion of the match?
4. Which programming language did you use?
5. Could you post a copy of your code?
Michael
Unread 03-02-2009, 23:28
saaby's Avatar
AKA: Taylor Cannon
Yes we used the latest templates (they worked with our software following the setup process that the competition used too)
yes we started the autonomous code manually ( we had it working with our software)
tele-op went smoothly
program in robotC
(side note - only two or three teams there had autonomous code that worked. every other team's robot just sat there during autonomous, but they may not have even tried to use autonomous)
Unread 04-02-2009, 08:14
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
We have competed in VA in December and Delaware on Jan 31. Our autonomous has always started. We use LabView however. I know in Delaware teams used RobotC in autonomous successfully.
One thing we did was to arrive the night before and check out our code while the tournament organizers checked out their field. It was a win-win situation.
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
Unread 04-02-2009, 18:07
1. Did you install the new JoystickDriver.c file?
2. I will check the ROBOTC code of you post a copy. I would like to see the autonomous and tele-op files so that I can verify that the motor and servo settings are the same in both files.
Michael
Unread 04-02-2009, 23:39
saaby's Avatar
AKA: Taylor Cannon
I don't have the teleop code, it is on a laptop that stays at my school. I worked on the autonomous code primarily. This is what ours looked like..
#pragma config(Hubs, S1, HTMotor, HTMotor, HTServo, none)
#pragma config(Sensor, S3, , sensorTouch)
#pragma config(Motor, mtr_S1_C1_1, motorD, tmotorNormal, openLoop)
#pragma config(Motor, mtr_S1_C1_2, motorE, tmotorNormal, openLoop)
#pragma config(Servo, srvo_S1_C3_1, ser1, tServoNormal)
#pragma config(Servo, srvo_S1_C3_2, ser2, tServoNormal)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
const tSensors touchSensor = (tSensors)S3;
// Autonomous Mode Code Template
// This file contains a template for simplified creation of an autonomous program for an FTC
// competition.
// You need to customize two functions with code unique to your specific robot.
#include "JoystickDriver.c" //Include file to "handle" the Bluetooth messages.
// initializeRobot
// Prior to the start of autonomous mode, you may want to perform some initialization on your robot.
// Things that might be performed during initialization include:
// 1. Move motors and servos to a preset position.
// 2. Some sensor types take a short while to reach stable values during which time it is best that
// robot is not moving. For example, gyro sensor needs a few seconds to obtain the background
// "bias" value.
// In many cases, you may not have to add any code to this function and it will remain "empty".
void initializeRobot()
// Place code here to sinitialize servos to starting positions.
// Sensors are automatically configured and setup by ROBOTC. They may need a brief time to stabilize.
return;
// Main Task
// The following is the main code for the autonomous robot operation. Customize as appropriate for
// your specific robot.
// The types of things you might do during the autonomous phase (for the 2008-9 FTC competition)
// are:
// 1. Have the robot follow a line on the game field until it reaches one of the puck storage
// areas.
// 2. Load pucks into the robot from the storage bin.
// 3. Stop the robot and wait for autonomous phase to end.
// This simple template does nothing except play a periodic tone every few seconds.
// At the end of the autonomous period, the FMS will autonmatically abort (stop) execution of the program.
task main()
initializeRobot();
waitForStart(); // Wait for the beginning of autonomous phase.
//variables
int moveforwarddone = 0; //flag for once done moving forward
short startTime; //time at start of loops
int turnleftdone = 0; //flag for once done turning left
int turnrightdone = 0; //flag for once done turning right
int liftarmdone = 0; //flag for once done lifting arm
int lowerarmdone = 0; //flag for once done lowering arm
int reversedone = 0; //flag for once done reversing robot
short pulleymotor1; //motor variable that assists servos
short pulleymotor2; //motor variable that assists servos
//// Add your robot specific autonomous code here. ////
while (true)
startTime = (short)nPgmTime; //set the program time back to 0
while(nPgmTime < startTime + 3000) //approximate distance from wall needed to turn
//while the sensor reads more than 13 cm. away from wall move forward full speed
motor[motorD] = 127;
motor[motorE] = -128;
moveforwarddone = 1;
// turn robot left
if(moveforwarddone == 1)
while(nPgmTime < startTime + 500) // change to compass sensor -- need to get bearings once we get to competition location
motor[motorD] = 127; //full speed with right wheel(make sure right wheel is motor A)
motor[motorE] = 127; //full reverse left wheel (make sure the left wheel is motor B)
turnleftdone = 1;
moveforwarddone = 0; //reset moveforward done
//move robot towards the trough (3' 5.5") about 106 cm. NEED TO TEST PROBABLY HAVE TO RUN FOR TIME
if(turnleftdone == 1)
while(nPgmTime < startTime + 2000) //may need to lower or increase the amount of time for raising arms
motor[motorD] = 127; //move forward maximum speed
turnleftdone = 0; //reset turnleftdone
moveforwarddone = 1; //move forward done == 1 after bot reaches required position
//turn back to original position
while(nPgmTime < startTime + 250) // run while heading != original heading (forward)
motor[motorD] = -128; //full reverse with right wheel
motor[motorE] = -128; //full speed with left wheel
turnrightdone = 1;
//lift arm to necessary hight (20.75") raise for time
if(turnrightdone == 1)
while(nPgmTime < startTime + 2000) // make pulleymotors lift to assist servos
motor[pulleymotor1] = 127;
motor[pulleymotor2] = 127;
servo[ser1] = 80; //make both servos lift the arm at maximum speed
servo[ser2] = 175;
liftarmdone = 1;
moveforwarddone = 0; //reset move forward done
//move robot towards the wall to get arm close enough
if(liftarmdone == 1)
while(nPgmTime < startTime + 250) //approximate distance from wall needed to turn
liftarmdone = 0; //reset lift arm
//lower arm if near a wall
while(nPgmTime < startTime + 2000) // make pulleymotors lower
motor[pulleymotor1] = -128;
motor[pulleymotor2] = -128;
servo[ser1] = 0; //make both servos lower the arm at maximum speed
servo[ser2] = 255;
lowerarmdone = 1;
//turn robot so that back faces straight towards the scoring area
if(lowerarmdone == 1)
while(nPgmTime < startTime + 150) // run while heading != original heading (about 20 degrees)
turnleftdone = 1;
lowerarmdone = 0; //reset lower arm done
//reverse robot to scoring area
while(SensorValue[touchSensor] < 100 ) // run while touch sensor is not pushed in
motor[motorE] = 127; //full reverse with left wheel
turnleftdone = 0; //reset lower are done
reversedone = 1;
//score pucks until time runs out
if(reversedone == 1)
servo[ser1] = 110; //raise arm at full speed
servo[ser2] = 145;
Unread 05-02-2009, 10:52
I adjusted the code to work with a simple test setup of an NXT connected to two NXT DC motors. I implemented the changes below and tested them with the Field Management System. I didn't test the servo code, however, you will be able to do this on your robot after making the following changes:
1. startTime should be declared "long", not "short". nPgmTime starts counting when the program starts on the NXT. By the time all four robots are on the field and ready to go and the Field Management System starts the autonomous mode, nPgmTime is a very large number, exceeding the range of the short variable startTime. You can observe the value of nPgmTime (scaled to seconds) in the System Parameters Debug Window while executing the program inside ROBOTC. Also, see next item 2 below.
2. Remove "(short)" in the code where startTime = (short)nPgmTime;
3. Reduce the maximum motor commands. The HiTechnic and NXT motors have a range of -100 to +100.
4. pulleymotor1 and pulleymotor2 are not declared in the Motor Setup. From the ROBOTC task bar select: Robot --> Motors and Sensors Setup. Select the Motors tab and assign pulleymotor1 and pulleymotor2 to a Port.
5. The autonomous code will continue to loop [run again] unless you add a "StopAllTaks():" after the last while loop.
6. Set motor commands to zero when leaving motor and servo while loops. Create a function such as:
void stopMotors()
motor[motorD] = 0;
motor[motorE] = 0;
You can implement a similar function if you want to stop servo movement:
void stopServos()
servoTarget[servo1] = ServoValue[servo1];
Replace "servo1" with the name of your servo.
Call the appropriate function(s) after exiting a while loop.
7. Add the stopMotors(); and stopServos(); function calls to the initialization section of the autonomous program. See "void Initialize Robot()" towards the top of the program code.
Michael
Unread 05-02-2009, 20:45
saaby's Avatar
AKA: Taylor Cannon
Thank you for all of those points. I had thought of several, but forgot to fix them in my code.
Unread 19-02-2009, 12:45
nate15810's Avatar
nate15810 nate15810 is offline
World's Most Clueless Programmer
FTC #0154 (154 Renegade)
nate15810 is an unknown quantity at this point
OK I HAD A PROBLEM WITH RUNNING AUTONOMOUS, BUT I FIXED IT...
DOWNLOAD THE AUTONOMOUS FIRST THEN DOWNLOAD TELEOP...
CONNECT TO THE FMS THEN RUN AUTONOMOUS...
WHEN THE AUTONOMOUS RUNS (on the FMS) IT'LL RUN AUTONOMOUS
THEN IT'LL SWITCH TO AUTONOMOUS
AUTONOMOUS WILL STILL BE SHOWN AS TELEOP THOUGH
yeah I had a huge problem and i couldn't delete my post, so i decided to post MY solution
Originally Posted by Joe Martin
The most overlooked advantage to owning a computer is that if they foul up there's no law against wacking them around a little.
Our Sponsor:
Our Site
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
Video: FTC 3 Cloverfield Autonomous Synergy1848 Robot Showcase 0 26-02-2008 14:34
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
