Go to Post The Questions is, do we attempt to build a Mr.Fusion, or do we go for the Plutonium from the Libyans? - dag0620 [more]
Unread 01-02-2009, 21:05
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Team1710 is an unknown quantity at this point
Re: Chain
Yea we looked into this but the chain generated only has two gear positions. Two of the chains we are using contact at four points. Another two chains contact at three points. Plus when using those parts we were unable to make the files even visible. They were only visible when selected. If we were to use chain generator using ANSI 40 would this hurt or improve chances for the Autodesk Visualization Award?
Unread 02-02-2009, 00:56
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: Chain
If you look at the properties for chain, their should be a dropdown for ANSI 35 chain. I was able to make the Roller Chain Generator create 35 chain for a basic kitbot.
Let me know if you can't find it, I will put up a screenshot
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 02-02-2009, 09:09
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Chain
Originally Posted by pearldrumzach View Post
JD - I created a chain, with the correct number of links. ...Is there any way I can make the chain "work"
Do not create all of the links.
You need only one roller link and one pin link (depending on the type of chain used - I haven't looked at the supplied).
Create an ipt with the path (actually I think the DAcc does this for you).
Create one workpoint on the path.
Use the Curve Driven Pattern tool (missed named - Rectangular Pattern) to pattern the workpoint at the correct pitch around the path.
(see http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf - not exactly the same thing so don't get confused, but it should get you going)
Then in the assembly place the one (or two) links as needed and constrain to the points. Then use Pattern Component using the point pattern to drive the palcement of the rest of the links around the path.
To actually animate the movement of a chain is more difficult than I can explain here.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 02-02-2009, 13:46
pearldrumzach pearldrumzach is offline
FRC #0401
pearldrumzach is an unknown quantity at this point
Re: Chain
I tried this; I created the .ipt with the path, and made a workpoint. However, when I tried to array the point, it said that you are unable to array work features (I've been trying to work on chain at school and not cut into my time at the robotics shop experimenting with it, and we only have 2008 on our school computers; is that part of my problem with arraying?). Thanks for all the help.
Originally Posted by lynca View Post
The roller chain generator default in Inventor has a few quirks.
I suggest using one of thee 3rd party auto chain generator if you are having trouble.
http://www.sdotson.com/viewparts.php...20transmission
(check out the link with rollerchain.zip)
Let me know if you have trouble getting it to work
I've got everything set correctly in the Excel spreadsheet, and I can see the links when I mouse over them in the browser, but how do I make the chain visible?
Thanks for the help guys.
-Zach
Unread 03-02-2009, 00:34
Team1710's Avatar
FRC #1710
Re: Chain
This method is amazing! We're definately going to use this. Thanks a bunch!
Unread 03-02-2009, 16:57
JD Mather's Avatar
Re: Chain
when I tried to array the point, it said that you are unable to array work features...
-Zach
Are you doing Rectangular Pattern in ipt? Zip and attach what you have so far.
Chain hong12891 Inventor 8 05-02-2007 20:03
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
chain Lake Orion OCCRA 1 30-09-2001 13:20
