Go to Post Ken Patton rocks my socks off! - Josh Hambright [more]
Unread 31-01-2009, 13:20
mint564 mint564 is offline
FRC #0564 (Digital Impact)
mint564 is an unknown quantity at this point
downloading code to cRIO
what .out file do we need to use to download our code to the cRIO?
Unread 31-01-2009, 16:15
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Re: downloading code to cRIO
something like this:
workspace\BuiltinDefaultCode\PPC603gnu\BuiltinDefa ultCode\Debug\BuiltinDefaultCode.out
It'll change depending on what the name of your project is obviously.
Unread 31-01-2009, 22:48
You can find your current .out with the help of the Project Explorer window in the upper left.
Start expanding the project you're working with.
Expand PPC603gnu, then keep expanding down through your project, through "Debug".
Eventually, you'll see your project .out
You can also use the File Navigator tab in that window and get a list of all your files, including all your .out files and their directory path.
Just be careful if you have many projects with many .out files to pick the right one.
Unread 02-02-2009, 21:43
we tried that, but when we tried to download it our cRIO told us it had no code, we tried reimaging the cRIO a couple of times, we restarted everything multiple times, and it still told us no code, we dont know whats wrong
Unread 02-02-2009, 22:58
Are you trying to use one of the examples or something new that you wrote?
After you reimaged the cRIO did that default code work okay?
Unread 03-02-2009, 20:34
we're trying to download the default code from the WPI website, when we reimaged the cRIO the default code worked fine
Unread 10-02-2009, 19:30
pagemauck pagemauck is offline
pagemauck is an unknown quantity at this point
Wondered if you ever resolved this. We are in the same spot!
Trouble Downloading from LabView to cRio MikePres FRC Control System 0 15-01-2009 16:17
it seems there is no program in crio after downloading mahmosh C/C++ 12 12-01-2009 18:53
Problem downloading code Romeo1351 FIRST Tech Challenge 6 01-12-2006 06:33
Downloading code to 2005 RC Eclipse Control System 2 23-02-2006 19:58
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
