Go to Post You know what they say, the mind is the second thing to go and I can't remember the first. - GaryVoshol [more]
Unread 08-01-2009, 23:05
morganh2550's Avatar
morganh2550 morganh2550 is offline
Actuationator
FRC #2087 (BFG)
Team Role: Electrical
morganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nice
Cool Pneumatics Programing
Anyone have any ideas about programing pneumatics in LabView?
Unread 08-01-2009, 23:39
Re: Pneumatics Programing
Here is a simple form of the compressor and controlling a solenoid from the trigger of joustick 2.
There is a "Solenoid with Compressor Example" too you can look at on the LabVIEW startup screen.
Unread 08-01-2009, 23:46
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
You use the Solenoid Breakout and the Solenoid VIs
http://www.usfirst.org/uploadedFiles...s-Rev-0-5a.pdf go down to Solenoid Breakout. It plugs into one of the cRIO modules.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 10-01-2009, 17:05
Actuationator
FRC #2087 (BFG)
Talking Re: Pneumatics Programing
Thanks for the help!!!
Unread 10-01-2009, 18:25
Kaushal.K's Avatar
Kaushal.K Kaushal.K is offline
Scouting & Things
AKA: kkaboose
FRC #1241 (THEORY 6)
Kaushal.K is an unknown quantity at this point
I have a quick question, in the Advanced Framework, how do we get all the code parts (eg. USB 2.. or Solenoid 1.. or Relay 6)?.. were they just made up or are they in the WPI Robotics Library?
thanks for the help, the code samples were really helpful
FRC Volunteer Coordinator (2015 - Present)
FRC Robot Inspector (2012 - Present)
FRC 1241 - Alumni & Mentor (2007-Present)
Unread 10-01-2009, 21:12
Those are enumerated in the LabVIEW FRC palettes.
You automatically get them when you wire a Constant to the WPI vi's, such as, Joystick Open.
Unread 03-02-2009, 21:21
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
I looked at your example, but i am unable to tell how the program knows that it is to run off the trigger of joystick 2. In our setup, we have a third joystick used to control two motors and hopefully also used to control our solenoid with the trigger of joystick 3. any ideas?
Unread 04-02-2009, 00:23
Does it help to know that button 1 is the trigger on the KOP joysticks?
Each of the joystick buttons has the number printed on it except for the trigger of course.
In that example the USB 2 joystick is opened, and button 1 (the trigger) is feed into and controls the solenoid.
If you want to use the trigger on joystick 3 instead, just change "USB 2" to "USB 3" in that example.
In normal usage you'd put all this in the same loop you use the joysticks to tank/arcade drive.
Unread 04-02-2009, 08:16
FRC #2909
This code will be used in the same loop as our tank drive setup, but i'm still a little confused. In the link you provided, there isn't a Joystick open .vi or anywhere to change the USB 2 to USB 3. I understand that the trigger is button one on the joysticks. In our setup, joysticks 1 and 2 run tank drive. Will i need to program the trigger of one of those joysticks?
I guess my question is, in the example that you provided, there never is a specified USB value. It goes from compressor open, to compressor start, to compressor stop and close.
Unread 04-02-2009, 08:52
I think we're looking at different examples.
Take a look at the link to controlling a solenoid that was posted in another thread on the same topic.
CD doesn't allow me to repost it in this thread.
It uses "USB 2" on the left side of the diagram.
Unread 04-02-2009, 08:54
FRC #2909
ah yes, this solves my problem. Thanks a lot.
Unread 04-02-2009, 09:06
FRC #2909
one more question....do i need to place the code for my compressor and solenoid valves in the teleop case loop inside my while loop? or can i just place it in it's own while loop?
Unread 04-02-2009, 09:40
You want the solenoid check inside your teleop loop, since that's where you are reacting to joystick commands.
The compressor you want operating in both autonomous and teleop modes so that goes elsewhere.
Really, the compressor Open and Start should be in the Begin.vi and the Close in Finish.vi. You need to add the compressor cluster information to RobotData.ctl so it can be used in the Finish.vi
P.S. I'm assuming by what you said that you're using the Advanced Framework. If you're using the Basic one instead it's a little different.
Unread 04-02-2009, 11:19
FRC #2909
thanks, that helps.
Unread 04-02-2009, 13:18
FRC #2909
Okay, I just sat down to program this setup and i realized that this is a timed function. How do I incorporate the timed function within my teleop loop without it affected the entire teleop loop?
starting programing... xanarchyx Programming 4 05-01-2008 23:48
Programing mormannoob FIRST Lego League 5 03-04-2007 14:02
Programing great_one411 General Forum 2 01-02-2003 17:27
Programing of controller DLyons Programming 0 29-11-2002 20:50
Programing pfortunejr Programming 1 08-01-2002 13:18
