Go to Post "automated chaos" nuff said. - Jferrante [more]
Unread 18-01-2009, 04:07
tuna.and.cheese tuna.and.cheese is offline
None #0333
tuna.and.cheese is an unknown quantity at this point
Car Steering...
Hi everyone. I am trying to implement direct drive where all four motors are connected directly to all four wheels. I also want these wheels to each turn like a car would to make turns. If the joystick is in the upper left position, the robot will turn left and go forward and if in the right position, the same but turn right. The drive train is already built and the electronics are on the robot, but I am yet to attempt to program this and am just in the research stage.
Would anyone know how I could go about attempting this? I could get the robot to go foward and back, but to do this while at the same time rotating motors to turn left or right is not making too much sense.
Any help will be great. Thanks. Justin.
Unread 19-01-2009, 00:42
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: Car Steering...
Car style steering is called Ackerman steering. If you search for that there are a number of useful articles on the web. A number of teams used this in 2008. A team I worked with some used it and one problem they had was coming up with a way of "holding" the steering position. The natural tendency of these systems is to "want" to return to driving straight. Let go of the steering wheel of a car while it's moving and see what happens.
Unread 03-02-2009, 23:15
gokul gokul is offline
FRC #0571
gokul is an unknown quantity at this point
Re: Car Steering...
Are you using additional motors to steer? Your post says all 4 motors are connected to the 4 wheels.
The functionality you are describing seems similar to the Arcade Drive provided by the WPILib classes.
You may want to look in to the details of the Tank and Arcade Drive options provided in LabView and WPILib C++ classes and figure out how your motors should be paired and connected to achieve what you are trying to do.
Steering individual wheels would need steering motors/servos or some such mechanisms in addition to your drive motors.
Try fixing/locking your drive wheels in "straight" configuration and experimenting with the above drive options.
Please post your findings.
Unread 25-02-2009, 21:51
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
Re: Car Steering...
Sorry I didn't see this post earlier. We're also implementing 4WD, car steering, and hopefully will able able to do ASR. Ackerman and differential are calculated. I did the theory and math stuff and the controls guys handled the actual code (though I haven't seen a full demo yet). Do you still need this info?
Cheers,
-Neil.
Programming Direct drive with Direct (car like steering) tuna.and.cheese Programming 2 18-01-2009 11:26
pic: steering edomus Extra Discussion 10 05-06-2005 11:12
Steering Wheels Chris_Elston Programming 3 17-01-2005 15:31
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
tank steering archiver 2000 10 23-06-2002 22:28
