Go to Post All the gangstas in FRC have solid gold CRios. It's called "blingage". If you don't have a solid gold CRio, you're not a straight-up G. :D - Jamie Kalb [more]
Unread 03-02-2009, 23:10
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
pic: 2745 S.A.R. Week 4
Unread 03-02-2009, 23:11
zachjo's Avatar
zachjo zachjo is offline
Shake 'N' Bake
FRC #0171 (Cheese Curd Herd formerly Extreme Engineering)
zachjo is a jewel in the roughzachjo is a jewel in the roughzachjo is a jewel in the rough
Re: pic: 2745 S.A.R. Week 4
looks intesesting. I've seen the tubing used with a roller on several robots, how do you mount the tubing in the roller?
unicycling----It's like doing a wheelie forever!
Shake 'N' Bake
Unread 03-02-2009, 23:21
AKA: Rudy
FRC #5572 (Rosbots)
well we drill a hole in the pvc and use puematic wiring and stuck the puematic wire in the drill hole.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 04-02-2009, 10:45
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
how is the eight wheel drive working for you?
295 Team Captain
Unread 04-02-2009, 11:25
GillSt.Bernards's Avatar
GillSt.Bernards GillSt.Bernards is offline
AKA: Amanda Cullen
FRC #2458 (Team Chaos)
GillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to all
Send a message via AIM to GillSt.Bernards
Interesting with the 8 wheel drive.
"A Dream is just a dream, a goal is a plan with a deadline" - Fortune Cookie-
"Life is a runaway train you can't wait to jump on"
-Sugarland (Already Gone)-
Unread 04-02-2009, 13:03
tanmaker
Posts: n/a
Drill the hole a tiny bit bigger than the diameter of the pneumatic tubing, then load up the holes with hot glue. Push the pneumatic tubing into the hols, and the extra space will allow the hot glue to harden and keep the tubing where it is. It works pretty well.
Just pushing the tube into tight holes will not work, you need some glue to keep them in place.
Unread 04-02-2009, 13:36
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Interesting design. If that is 1/8" walled aluminum and this is olny half the robot, how heavy are you guys right now?
Unread 04-02-2009, 14:02
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Horray for the kit chassis!
If weight savings is needed, that #35 chain could be changed into #25 chain pretty easily.
Collin Fultz
Unread 04-02-2009, 21:49
AKA: Rudy
FRC #5572 (Rosbots)
That wieghs around 65 lbs. and the 8 wheel design is working good for use we delvoping a clutch system to help with traction.
[size="1"]
pic: Blizzard X - Week 4 Mr. Lim Extra Discussion 9 30-01-2009 14:36
MOEmentum FYI - Week 3: It's Week Three Already?!? Mr MOE General Forum 0 18-01-2009 19:23
pic: 97: Week 4 ZZII 527 Extra Discussion 6 05-02-2008 15:45
MOEmentum: Week 3 - It's Week 3 Already? Mr MOE General Forum 3 22-01-2008 10:16
FIRST to reduce 6-week building period to 5-week archiver 2001 12 24-06-2002 01:27
