Thread Tools |
Rating:
Display Modes |
Re: need help with gyro sensor connection
You need 1 pwm for your rate output and 1 pwm for your temp output. They're seperate circuits, so you can't run 5v to the rate side and get a temp output
thank u for ur help.......
u said we need two pwm cables the first to the analog input where we have to connect the scand pwm cable? |
Basically, your gyro's i/o should look something like this
Rate o o o Tempo o o Each circuit needs a signal output, a 5v input, and a ground. So you wire up the PWMs parallel to the rate/temp labels. |
thx for ur help
can anyone put a pic of the gyro with the pwm cable connections ? the second thing we have the second pwm cable from temp 000 where i have to connect it? team#1946 |
| Help With Gyro | Bronson | Electrical | 3 | 10-01-2008 21:09 |
| Need help with gyro turn | magical hands | Programming | 2 | 11-03-2007 21:53 |
| Need help with Gyro = Analog Devices ADXRS150EB | Jack Jones | Technical Discussion | 9 | 18-07-2005 07:00 |
| With gyro need to access ADC for poteniometer | mrozek | Programming | 0 | 21-02-2005 13:39 |
| Need help with Sensor | Hop_of_752 | Programming | 5 | 06-02-2004 23:43 |
