Re: Linksys Gaming adapter
The Access Point for the FRC arenas are self power adjusting per connection depending on the signal strength they get back from the Bridge. They are very powerful. Extensive testing has shown the links to be very reliable within the confines of the field. With that said though, do not encase your bridge inside a faraday cage, i.e. metal all around it somehow grounded....
Flat or set on an end will not matter as long as it is reasonably clear of metal obstructions and try to keep it as far from motors and relays as possible to minimize emp and magnetic interferrences. If you're having some sort of reception issue, there's lots of documentation on the web about placing capacitors across motor leads to reduce radio noise.
BotBash BOB Pitzer
Harvest CROO Robotics and 4FX Design
