Go to Post Like my programming class teacher has said multiple times: "Stop complaining on reddit about your code not compiling and actually fix it". - [more]
Unread 02-02-2009, 20:21
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Linksys Gaming adapter
We were wondering if anyone knows what the best oriantation of the Linksys Dual-band Gaming Adapter is? We know from the way you conntect it to the robot that it is probubly at a 90 degree angle.
Thanks!
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 02-02-2009, 22:46
Re: Linksys Gaming adapter
Make sure you can see the LEDs!
Unread 03-02-2009, 18:04
We know this, but what is the best oriantation for the internal antenna? We have looked at several sites (here, the FIRST Forums, Cisco, and gaming blogs...) however we still cannot find the BEST oriantation for the adapter!
Any help?
Sarah Heimlich
FIRST® TEAM 3132
Unread 03-02-2009, 18:08
The internal antennae are reasonably omni-directional, so it shouldn't really make much of a difference. Make sure everything is visible, try not to bury it in metal, etc.
I'm sure that there is an optimal orientation, but the margin in the link budget means that it won't make enough of a difference to be worth the effort/analysis.
Unread 03-02-2009, 19:09
We were also wondering if there is a diagram of the internal workings of the gaming adapter?
Sarah Heimlich
FIRST® TEAM 3132
Unread 03-02-2009, 19:14
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Sorry - that's a Linksys/Cisco product and I'm guessing that they're not terribly interested in publishing a lot of those details.
It's obvious got a dual-band radio (2.4 and 5GHz), a processor for handling the 802.11x protocol and an Ethernet MAC/PHY device(s). Beyond that, what are you looking for?
Russ
Unread 04-02-2009, 01:01
pitzoid's Avatar
pitzoid pitzoid is offline
AKA: BOB
no team (4FX Design)
pitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of light
The Access Point for the FRC arenas are self power adjusting per connection depending on the signal strength they get back from the Bridge. They are very powerful. Extensive testing has shown the links to be very reliable within the confines of the field. With that said though, do not encase your bridge inside a faraday cage, i.e. metal all around it somehow grounded....
Flat or set on an end will not matter as long as it is reasonably clear of metal obstructions and try to keep it as far from motors and relays as possible to minimize emp and magnetic interferrences. If you're having some sort of reception issue, there's lots of documentation on the web about placing capacitors across motor leads to reduce radio noise.
BotBash BOB Pitzer
Harvest CROO Robotics and 4FX Design
Help for the Cisco linksys router? star_lancer Technical Discussion 2 31-01-2009 14:34
Fubar Gaming Adapter Lord Byron FRC Control System 4 15-01-2009 17:43
Gaming Adapter Orientation On Robot: Does it matter? Tom Line FRC Control System 1 12-01-2009 12:48
Gaming to help vision! Heretic121 Chit-Chat 3 07-02-2007 19:02
Linksys Router Help mtaman02 Chit-Chat 10 18-03-2004 01:04
