Go to Post I am a 2-3 year competition veteran, and a new member at chief delphi, and everyone here seems to be as nice as they are at the competition. Very gracious, you might say. - Ian S. [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Unread 29-01-2009, 12:15
ferc ferc is offline
ferc is an unknown quantity at this point
Smile PRO-E TUTORIALS
HI !
Can anyone post where can we find free pro-e tutorials? May be video tutorials or text based as well.
Thanks,
Murthy
Unread 03-02-2009, 16:25
PTC_FRC PTC_FRC is offline
PTC_FRC is on a distinguished road
Re: PRO-E TUTORIALS
Hello,
As a FIRST team member, you can access web-based training for Pro/E from the following link - http://first.ptculms.com.
You will need to regsiter for the site.
Once registered, you can choose the online courses link on the left hand menu and then choose the desired course.
WE have courses on modeling, detailing, assemblies and mechanism.
Hope that helps.
Mark
Unread 04-02-2009, 01:31
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: PRO-E TUTORIALS
I was also wondering where to get a free copy of PTC Wildfire?
R.C.
MadTown Robotics Team 1323
Unread 04-02-2009, 09:23
Re: PRO-E TUTORIALS
Hi Murthy,
You can access the free Pro/E seat for you and your team from Projectlink. This is the web collaboration portal that each team can use. This will allow you to manage your data online, enabling all team members to have access to the latest and greatest data via the web.
To regsiter for the project, click www.ptc.com/go/frcregistration
Thanks,
Mark
Unread 04-02-2009, 10:40
Re: PRO-E TUTORIALS
Hi Mark,
Thanks for your suggestions.Can you tell me are there any means by which i can convert my assembled model into mechanism?
Are both mechanism and animation in pro-e same?
Unread 07-02-2009, 10:32
Re: PRO-E TUTORIALS
Hi Murthy,
The methods of creating a mechanism joint is a combination of static constraints. When an assembling a component with static constraints you typically need to define three constraints to make it full constrained. However if you only applied two, you can convert that to a mechanism constraint.
For example, when you assembly with a insert constraint and a mate constraint, you can convert that to a pin joint (mechanism constraint). A pin joint is defined by axis of alignment (insert) and translation plane (mate). You do not have to delete and create over again. In the dashboard for the assembly, there is an icon to convert from static to mechanism or vice versa.
I have accepted you into the PTC U training at http://first.ptculms.com.
Take a look at the mechanism course.
Thanks,
Mark
Unread 07-02-2009, 11:41
Re: PRO-E TUTORIALS
Thanks Eric,
For accepting me into online training course.I would like to know how to change the dimensions of the assembled component?
Regards,
Murthy
Unread 08-02-2009, 10:48
Re: PRO-E TUTORIALS
Hi Murthy,
What dimensions were you refering to?
Assembly component dimensions....for placement offeset or something like that? Or do you mean component feature dimension modification?
Thanks,
MArk
Unread 08-02-2009, 20:40
Re: PRO-E TUTORIALS
Hi Mark,
I was referring about the individual component in an assembly
Thanks,
Murthy
Unread 12-02-2009, 13:21
Re: PRO-E TUTORIALS
Hi Murthy,
There are two ways to do this.
While in Assembly, you can select the component in the model tree and click the Right Mouse Button and choose activate. This will activate the part as if you where working on it by itself. You can add new features and edit existing features as you do in part mode. Give that a try. The nice thing about doing this in the assembly level is you can see how things interact with one another when making a change. When you are finished, click the assembly from the model tree and activate it via the right mouse button option.
Otherwise, select the component form the model tree and click the right mouse button and select Open. This will open the part in a new window.
Hope that helps.
Mark
Unread 15-02-2009, 14:45
Re: PRO-E TUTORIALS
Hi Mark,
I would like to change the length dimensions of the c-channel imported from the CAD FRC library of parts.But when I try to right click the c-channel, no sketch feature or extrusion feature of c-channel appears in the model tree.
So i couldn't edit the sketch or extrusion length to change the length of the channel.Kindly let me know how to modify it.
thanks and regards,
Murthy
Unread 25-02-2009, 11:33
Re: PRO-E TUTORIALS
Hi Murthy,
Did you download the parts from www.ptc.com/go/firstkop? Or did you download it form the www.firstcadlibrary.com?
If you downloaded it from the firstcadlibrary.com, the files are not native Pro/E. You would not be able to modify the dimensions.
I suggest you grab the same model from the ptc.com site....as they are native Pro/E models.
let me know which ones you grabbed and we can discuss the steps to edit.
mark
Unread 26-02-2009, 14:16
Smile Re: PRO-E TUTORIALS
Hello Mark,
I think grabbed the parts from firstcadlibrary.com.But I'm almost done with the model now.However I'm terrible need of your help in conducting dynamic analysis which are described as follows:
(1) to determine the velocity at which if the robot hits an object it can tip off
(2) to check the displacement of the robot when certain amount of force is applied to the robot on its structure
I tried several online resources to find this but I could get any lead on this.
Can you clearly tell me how to conduct this.Also I think this portion of analysis was not available in the online classes.
Waiting for your support,
Thanks and regards,
Murthy
Unread 05-03-2009, 14:24
Re: PRO-E TUTORIALS
Hi Murthy,
Send me an email with the details and we can look at the problem.
mfischer@ptc.com
Thanks,
Mark
Unread 06-07-2010, 11:25
skotmorris's Avatar
skotmorris skotmorris is offline
Windchill Product Manager
FRC #4909 (Bionics - Billerica Memorial High School)
skotmorris is an unknown quantity at this point
Re: PRO-E TUTORIALS
PTC has recently updated our Hands On Workshop tutorials from Pro/ENGINEER Wildfire 4.0 to Wildfire 5.0 and has them available for download on www.ptc.com/go/firstgettingstarted.
NI Tutorials comphappy Programming 0 18-08-2008 00:36
Tutorials RRA4LIFE2 Programming 1 06-01-2008 09:21
Whats your opinion, Pro-life or Pro-Choice? efoote868 Chit-Chat 5 28-09-2007 10:11
Easy C Tutorials jbbjjbt Programming 3 21-02-2006 08:40
Tutorials Leon Machado IV 3D Animation and Competition 13 25-01-2004 23:10
