Go to Post FIRST is not about robots or which roller coaster we get to ride... it is about people. - Andy Baker [more]
Unread 02-02-2009, 10:02
nadavsen2 nadavsen2 is offline
FRC #2231
nadavsen2 is an unknown quantity at this point
Still problem with classes...+img
I just can make that thing work....
image:
Unread 02-02-2009, 15:06
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Re: Still problem with classes...+img
It looks like you are trying to create an object for the "Drive" class....right??
I think you were trying to write:
RobotDrive *bba;
Maybe I'm missing something? Please elaborate.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 02-02-2009, 17:53
FRC #2231
Yes, im trying to creat a new object "Drive" (!!)
I defined a new object at the class "Drive" and i want to make a new
object in my code. Like "PWM" or "Jaguar" but from class that i created!
help
Unread 04-02-2009, 02:18
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
Mind showing us more of that MyRobot.cpp file you're using? If you could post that, along with your Drive.cpp and Drive.h files, then it'll be easier to figure out than working from just a screenshot.
Which badges can you claim?
Unread 04-02-2009, 02:34
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
You want something like
RobotDrive *bba = new RobotDrive(1, 2);
There is no class Drive in the WPI libraries (I think).
Unread 04-02-2009, 03:31
FRC #2231
Im trying to creat one....
I succeid to creat a new class but now when im trying to put the code
on the cRio the DS tells me "No Code".
why is that?
here is my code:
MainClass
PHP Code:
#include "WPILib.h"
#include "Functions.h"
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
class RobotDemo : public SimpleRobot
RobotDrive myRobot// robot drive system
Joystick stick// only joystick
public:
RobotDemo(void):
myRobot(12),    // these must be initialized in the same order
stick(1)        // as they are declared above.
GetWatchdog().SetExpiration(100);
     * Drive left & right motors for 2 seconds then stop
void Autonomous(void)
GetWatchdog().SetEnabled(false);
myRobot.Drive(0.50.0);     // drive forwards half speed
Wait(2.0);                 //    for 2 seconds
myRobot.Drive(0.00.0);     // stop robot
     * Runs the motors with arcade steering.
void OperatorControl(void)
GetWatchdog().SetEnabled(true);
Functions r;
        while (
IsOperatorControl())
GetWatchdog().Feed();
myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
r.GetSomething();
START_ROBOT_CLASS(RobotDemo);
Functions.h:
PHP Code:
#ifndef FUNCTIONS_H_
#define FUNCTIONS_H_
class Functions
public:
void GetSomething(void);
#endif
Functions.cpp:
PHP Code:
Unread 04-02-2009, 06:44
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
PHP Code:
That should be:
Functions
PHP Code:
void Functions::GetSomething(void)
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 04-02-2009, 16:54
FRC #2231
Still not working..
Unread 04-02-2009, 18:10
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Does it compile? It looks like it should work (of course it does nothing).
Try downloading into RAM with the target console window up. Does it print any messages about undefined symbols? When you run it can you see the FRC_RobotTask running (type 'i' to see the running tasks).
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
Help!!! Question With Robotics Classes At School..? Cactus_Robotics Robotics Education and Curriculum 11 22-02-2008 10:53
Help!!! Question With Robotics Classes At School..? Cactus_Robotics Robotics Education and Curriculum 1 19-02-2008 20:56
Houston, we still have a weight problem. Elgin Clock Chit-Chat 0 03-01-2003 15:57
What keeps you off a team but still with FIRST? Jessica Boucher General Forum 14 13-06-2001 21:37
