Go to Post You don't have to build a winning robot to build a team, but you won't build a great team unless they are striving to build a winning robot. - Richard Wallace [more]
Unread 25-01-2009, 21:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: can we use 2 batteries?
Originally Posted by Chris Fultz View Post
Either you have forgotten something major, or you are my hero!
Most of the robot was together and on the scale...honest!
ID:	7225  Click image for larger version
Unread 26-01-2009, 14:04
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Last year we used a nice thick steel plate for some added ballast at the front of our robot. Helped prevent tipping, and brought us up to the weight limit. The plate started around 20lbs, but i think we ended up shaving off a little before competing.
hopefully we're under again this year so we can use some more steel plates to offset the battery, which is looking to be on one side of the robot, making us a little lopsided!
Unread 26-01-2009, 14:16
CraigHickman
Posts: n/a
We need a robot before we can worry about ballast... Woohoo crunch time!
Unread 01-02-2009, 18:49
gorillamonky gorillamonky is offline
FRC #0696
gorillamonky is an unknown quantity at this point
Ballast should be a simple problem to solve. although i like the sledgehammer and wrenches one.
it wasn't like that when we shipped it
Unread 03-02-2009, 20:56
haxor5354 haxor5354 is offline
AKA: Jason
FRC #1558 (ACCI-DENT)
Team Role: Electrical
haxor5354 is an unknown quantity at this point
no point of using 2 batteries anyways just bring a few fully charged battery for back up if necessary the robot would definitely not use up all the power after 1 match. unless if the battery is really old.
Unread 03-02-2009, 21:15
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
All teams really need to bring multiple batteries and multiple battery chargers to each regional. You should never start a match with anything other than a fully-charged battery and it can often take an hour or two to recharge a battery following a match. Bring plenty of spares!
Russ
Unread 04-02-2009, 10:16
Racer26 Racer26 is offline
You've obviously never built any high-torque treaded tank drive robots. 1075 has no trouble building a robot whose drivetrain will swiftly kill one of our batteries in as little as 10 seconds.
We had to fix that, obviously, but we were still just barely squeezing 2.5 mins out.
In contrast, our forklift cart powered by 2 12V deepcycle marine batteries in parallel with 2004's IFI system will run for an entire competition weekend on a charge. There is definitely a benefit to be had by running multiple batteries, HOWEVER, its not allowed. C'est la vie.
Unread 02-03-2009, 12:55
Team1824 Team1824 is offline
FRC #1824
Team1824 is an unknown quantity at this point
This year our robot with trailer hitch and bumpers weighed just over 105 pounds!
Unread 02-03-2009, 18:04
BPetry234's Avatar
BPetry234 BPetry234 is offline
Inventor Nerd
AKA: Ben Petry
FRC #0234 (Cyber Blue)
BPetry234 is a splendid one to beholdBPetry234 is a splendid one to beholdBPetry234 is a splendid one to beholdBPetry234 is a splendid one to beholdBPetry234 is a splendid one to beholdBPetry234 is a splendid one to beholdBPetry234 is a splendid one to beholdBPetry234 is a splendid one to behold
Anyone who has to look at batteries, wrenchs, lead plates, or anything else mentioned deserves an award as far as I'm concerned. Our robot is box, yet we were still only .2 under. You guys are engineering idols.
"If they didn't want winners and losers, they wouldn't keep score." Mr. Craig Potter
Unread 02-03-2009, 19:01
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
in 2007 we added 13 lead diving weights to the robot (zip tied to the frame for lowest possible CG.) The advantage was that they were meant for a diving belt, so they were relatively small, already coated with 1/8" rubber, and had a wide, thin slot for putting zip ties through.
Can We use fiberglass? hunter7 Rules/Strategy 2 16-02-2007 17:33
How many extra batteries should you bring, and where can you buy more? haverfordfords Electrical 6 08-02-2005 22:01
can we use? Allie Kit & Additional Hardware 5 13-02-2002 15:54
Can we use? Team537 General Forum 2 29-01-2002 16:49
Can we use Maya? Suneet 3D Animation and Competition 4 08-01-2002 14:44
