Go to Post "prepare to take flight"! I see people taking off shoes and waiting in long lines. - 346CADmen [more]
Unread 04-02-2009, 10:09
Mr. E Mr. E is offline
Its physics or stamp collecting
FRC #1883
Mr. E is an unknown quantity at this point
Default code
Our default code in LabVIEW has become....violated....How do I get the default code back? Do I have to reinstall LabVIEW from the CDs and then install the updates? Will someone please say no because that was not a short process.
Unread 04-02-2009, 10:21
Re: Default code
Do you mean the Advanced and/or Basic Framework or some examples?
You should be able to recover those original files, not from the original installation disks, but from another installation.
Any particular vi's that were corrupted?
I'll go look for them...
P.S.
The Frameworks are defined in:
C:\Program Files\National Instruments\LabVIEW 8.5\resource\plugins\NewDialogFiles\ProjectWizards \FRC\FRC Templates
The Examples are in:
C:\Program Files\National Instruments\LabVIEW 8.5\examples\FRC
What do you need?
Unread 04-02-2009, 10:33
FRC #1883
Re: Default code
The Basic robot main VI and the watchdog VI.
Unread 04-02-2009, 10:41
Re: Default code
Here's the Basic Robot Main vi.
It goes in: C:\Program Files\National Instruments\LabVIEW 8.5\resource\plugins\NewDialogFiles\ProjectWizards \FRC\FRC Templates\Basic Robot
The WatchDog vi's should be in a WPI library (WatchDog.lvlib) I think.
This is the entire contents of: C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\WPI\Watchdog
Some WatchDog vi's are hard or impossible to get to, for instance, FeedWatchDog.vi in:
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\NIFPGAInterface\WatchDog is password protected.
Note that these are as of Update 3a. I'll probably remove these attachments after you've picked them up, just so there is no confusion or conflict with later Updates.
Removed for the prevention of versionitis.
Unread 04-02-2009, 11:15
FRC #1883
Re: Default code
Just got em. Thanks Mark. A little installing and reimaging and we should be good as new.
Unread 04-02-2009, 12:46
Re: Default code
You should really just need to run the wizard from the launch screen or the New... again. Hopefully that will give you a clean start. If you go to the template location beware that there is a Real VIs folder that the wizard copies over the ones in the Advanced or Basic folder. The reason has to do with a workaround for FPGA and projects and Save As.
Anyway, I hope you get a clean copy, otherwise post again.
Greg McKaskle
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
