Go to Post I care that teams took some time to put in safe guards to prevent shrapnel hitting people because I'm selfish and I enjoy the use of all of my limbs. - Andrew Schreiber [more]
Unread 04-02-2009, 11:54
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Battery Display on DS
In the rules it states that we have to have the battery connected to the analog break out.
Originally Posted by <R64>
A National Instruments 9201 module must be installed in slot 1 of the cRIO Mobile Device
Controller. An analog breakout must be connected to this module. A jumper must be
installed on the “Battery Voltage” and “Power” pins on the analog breakout. The analog
breakout must be powered from the Power Distribution Panel. Please refer to Section 3.4 of
the “FRC Control System Component Data Sheets” for information on these connections.
and then it refers to this
Originally Posted by 3.4.2
1) Plug the Analog Breakout module into an NI 9201 analog input module and secure with
screws
2) apply power to J3 from the PD via 5A breaker and smaller WAGOs
3) select whether AI8 is to be connected to the 3x8 header or input power for battery sensing
and apply jumper accordingly
4) attach sensors via 3-pin PWM to the 3x8 header with careful consideration of polarity
Now here is the problem. Is the battery voltage suppose to show up next to "Battery" on the DS? We have done all these steps and it still says 00.00v but then when we read the analog input of AI8 it comes up as 7(ish)v which is about 40% of the 12v(as stated in the Q&A right below).
Spent a good amount of time searching, but didn't find anything that was really relevant to this.
Interacrtive Display PUFIRST Chit-Chat 1 09-04-2008 15:29
OI Display problem? Shu Song Control System 4 01-02-2005 20:42
OI Display problem? Shu Song Electrical 4 01-02-2005 20:42
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
LCD display James Crivellone Rules/Strategy 6 06-01-2002 10:22
