Re: Default code
You should really just need to run the wizard from the launch screen or the New... again. Hopefully that will give you a clean start. If you go to the template location beware that there is a Real VIs folder that the wizard copies over the ones in the Advanced or Basic folder. The reason has to do with a workaround for FPGA and projects and Save As.
Anyway, I hope you get a clean copy, otherwise post again. Greg McKaskle |
| Problems integrating CMUCAM code and IFI Default Code | Windward | Programming | 2 | 06-02-2007 16:48 |
| Modified default code gives "code violation" | scottmso | Programming | 8 | 10-02-2006 23:17 |
| problems using gyro/adc code with camera default code | tanstaafl | Programming | 7 | 22-01-2006 23:09 |
| user code to default code | phoenixomega001 | Programming | 5 | 09-01-2005 00:09 |
| Inserting Naviagation code into Default code? | actorindp | Programming | 3 | 28-01-2004 18:12 |
