Go to Post Boy you guys try to make my job harder every year. - Al Skierkiewicz [more]
Unread 04-02-2009, 02:46
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
Attaching KoP encoders
I was just wondering how are u supose to attach the encoders found in the KoP? when attaching it to the 1/4 inch axle on the gear box i was woundering how your suppose to attach the axle to the metal hub of the encoder. Are u suppose to use tape or something or like coder pin, set screw etc. although it would destroy the hub.
Unread 04-02-2009, 06:22
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Attaching KoP encoders
Andymark has installation instructions here.
Former Mentor Team 1771
Former mentor Team 4509
Unread 04-02-2009, 10:40
The encoder disk is plastic, not metal. If one is a little loose on the gearbox shaft, you can just carefully squeeze the sides of the encoder "hub" a little closer to make a tight fit.
Unread 04-02-2009, 13:17
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Get the encoder mounts from Andy-Mark if you have time. Like Alan said, I had to squeeze one of our disks to get it to stay tight on the shaft. (Squeeze before putting on the shaft).
Brian
Brian K
Team 1225 Robotics Mentor
Unread 04-02-2009, 17:23
DarKCroNo's Avatar
FRC #2670
so a bit of a squeeze would work? cause i'm worried if it may slip, although now that i think about it it probably wouldn't since theres nothing that would apply a force on the "hub" thanks!
KoP Quadrature Encoders ComradeNikolai Sensors 1 22-01-2009 14:22
Attaching Colors to Trailer UnknownMember Technical Discussion 0 15-01-2009 17:41
Attaching a lcd sonicx059 Programming 5 11-02-2008 09:41
Attaching sprocket to wheel sdcantrell56 Technical Discussion 3 15-01-2006 19:21
Attaching Potentiometers to VEX billbo911 FIRST Tech Challenge 9 07-07-2005 19:03
