Go to Post When we design these systems ask " would I want my Mom (or daughter) standing next to this thing when it goes off? - Mike Betts [more]
View Poll Results: Anyone ever had trouble with the toughbox motors before
Ooh Yes! 10 29.41%
Nope 23 67.65%
Do not use them 1 2.94%
Multiple Choice Poll. Voters: 34. You may not vote on this poll
Unread 04-02-2009, 13:59
GillSt.Bernards's Avatar
GillSt.Bernards GillSt.Bernards is offline
AKA: Amanda Cullen
FRC #2458 (Team Chaos)
GillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to all
Send a message via AIM to GillSt.Bernards
Toughbox Gearboxes
Whenever we turn the robot on the axel with one of the gear pops out and that falls down. The ball bearing has not popped out except for the first time today. Any reason why this would happen?
"A Dream is just a dream, a goal is a plan with a deadline" - Fortune Cookie-
"Life is a runaway train you can't wait to jump on"
-Sugarland (Already Gone)-
Unread 04-02-2009, 14:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Toughbox Gearboxes
Did you put the bearings in the right way, with the flange on the inside of the transmission, so they can't fall out?
Unread 04-02-2009, 14:01
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
http://lib.store.yahoo.net/lib/yhst-...rGuide2009.pdf
Above is a guide on how to assemble the toughbox. Hope this helps.
Peachtree '08 Champion Thanks 343 & 547
Galileo '07 Champion Thanks 173 & 1902
Palmetto '07 Champion Thanks 832 & 342
Boilermaker '06 Champion Thanks 1272 & 85
Unread 04-02-2009, 14:02
AKA: Amanda Cullen
yup they are on the inside
AKA: Amanda Cullen
according to the instructions they are assembled the right way but the axel is still popping out
Unread 04-02-2009, 14:14
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Just double checking, which gear and shaft is popping out? There are normally 4 gears in a toughbox and are driven in the following order:
CIM 14 tooth (On the motor) drives a 3/8" Hex 50 Tooth gear which is on the smaller of the two shafts.
1/2" Hex 14 Tooth on the same shaft then drives a 1/2" Hex 50 Tooth gear which is on the output shaft.
The more detail you can give me, the more I can help you. The other thing I could see is the output shaft pulling out if you really wore down some areas. But this is pretty unlikely. The other likely option is that the gear on the motor is pulling off, which would be the result of a missing key/retaining ring. But that doesn't really go with the bearing/shaft problems your talking about.
The more detail you can give us, the more help we can provide.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 04-02-2009, 14:30
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
We've had the push nut on the motor shaft works it way out until the key fell out. This cause one of the motor to spin freely. The only issue I see is the push nut. I'd prefer a set screw or event better an E-clip design but that would require machining the motor shaft. Some teams may not have the resources for machining the shaft.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
Unread 04-02-2009, 14:49
Moheeb698's Avatar
Moheeb698 Moheeb698 is offline
Airship Pirate
AKA: Moheeb Zara
FRC #0698 (Airship Pirates)
Moheeb698 is on a distinguished road
Send a message via AIM to Moheeb698
That happened to us as well. We fixed it by stacking some washers (each one with a key notch) and then we just put that in with the gear and it helped.
I know I'm forgetting some details here because I didn't do this myself, but when I find out exactly how we fixed it I'll repost.
Team 698: The Airship Pirates
Me: Why are you drilling your shoes?
Abdul: To make them lighter.
"Testtubes and Tesla coils,
clockwork brain 'n' glowing oils,
copper, brass, explosive jelly,
his mechapede policed Old Delhi.
Invented the radio transmitting, too.
Played poker with Theremin, Tesla and Poe.
Harnessed cold moonlight to power airships
and destilled antitoxines from postnasal drips. "
Unread 04-02-2009, 15:37
AKA: Amanda Cullen
Thanks we will try these at the meeting tonight and see if it makes a difference
Unread 04-02-2009, 15:46
http://www.chiefdelphi.com/forums/sh...7&postcount=10
Is this the type of problem you are referring to?
Unread 04-02-2009, 15:51
AKA: Amanda Cullen
No it's not the keys. we had that problem last year in which we lost the keys and we could not find them.
Unread 04-02-2009, 20:34
Engineer's Avatar
KØBR
AKA: Rick - KØBR
We stacked washers on both sides of the gear. Even if the push nut comes off, the gear and key cannot because the plate on the far side will not let the washers slip off the motor shaft. The last washer has to be larger than the hole in the far side plate.
Hello, from KØBR.
Unread 04-02-2009, 20:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We vastly prefer those splined retaining rings over any other method that can easily be done with the CIM shaft.
The only thing better in my opinion would be a snap ring, which isn't possible to do without disassembling and permanently damaging the motor.
2001-2004: Team 100
2006-Present: Team 254
Unread 04-02-2009, 20:49
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
One of our toughboxes had a problem with the key in the motor shaft jumping out and getting stuck in th grease on the inside.
It can be a good idea to put duct tape over the extra holes (keeps dirt out and keys in).
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Toughbox mounts Adama Inventor 6 28-01-2009 13:54
modified toughbox gorrilla Technical Discussion 7 02-04-2008 17:13
toughbox plastic side Andy L CAD 1 06-02-2008 23:26
Toughbox broken Evert Kit & Additional Hardware 5 05-02-2008 23:43
Toughbox Assembly mjgard General Forum 39 16-01-2008 19:27
