Re: FP Gearbox: Last stage gear?
That will depend on the size of the gear and the material. The smaller the teeth, the smaller the cutter, I assume.
Normally this requires an involute gear cutter(or hob), of which there will be several for the same Diametrical Pitch value, as the profile of the cutter needs to change a bit due to the number of teeth. You can also grind a peice of tool steel to make a form tool and use it as a single point cutter. OR if the tooth profile is large enough, you can use a properly sized end mill to cut the gear on a 3 axis mill. However this would likely be a very hard thing to accomplish(in something other than plastic / wood), for reasons I wont go into here. So, if you have a 4 axis CNC or a manual mill with a dividing head, or rotary table look into the involute gear cutters.
If you want to search around some, another word for gear cutting is hobbing. Here is one example http://www.youtube.com/watch?v=VHTXa...eature=related and here is another, using a different style cutter http://www.youtube.com/watch?v=62yme...eature=related Last edited by Justin Stiltner : 04-02-2009 at 16:15. |
| AM Planetary Gearbox (removing the fisher price gear/buying one without a gear) | Ice Berg | General Forum | 10 | 04-02-2009 15:43 |
| Last Year's Gear Ratio | AndyB | Technical Discussion | 4 | 11-11-2007 01:17 |
| BaneBots 56mm Gearbox - Second Stage Sun Seizing | Gary Bonner | Motors | 18 | 10-02-2007 12:52 |
| Last year's gearbox | MishraArtificer | General Forum | 3 | 10-01-2007 10:57 |
| Worm Gear Gearbox | dddriveman | Technical Discussion | 38 | 07-01-2005 14:43 |
