Go to Post The mission is to mobilize community, school and corporate resources to support the vision. The method is to provide an interesting, exciting program that gives young people opportunities to explore and expand their capabilities and interests. - Rick TYler [more]
Unread 04-02-2009, 15:37
Re: Wire Gauge vs Length (Signal)
How familiar with circuits are you? From the questions, you may have current vs voltage confused.
Originally Posted by Ewilliams2006 View Post
From the Control System's manual:
  • 5V/3A buck power supply for DSC circuitry with excess power available at the GPIO and I2C headers
Does this mean the DSC will source 3A to a nearly shorted connection, such as a depressed limit switch? What does "excess power" mean?
It means that it will reliably source 5V at up to 3A. If you draw more than 3A, the overcurrent protection will trip and temporarily shutdown the supply.
A limit switch has an effective resistance of 10kOhms when wired correctly, because of the 10k pullup resistor on the DSC. The effective impedence of the cRIO module's pin is very high.
Does the "Input current" mean that the module itself limits the input current to ±250 μA, or that is the maximum input current allowed into the module?
If a pin is set to an input and you apply between 0V and 5V, up to 250uA may flow. It is effectively stating the pin's impedance.
Finally, would adding a bypass capacitor across the ground and signal pins help reduce noise?
I'd stick it across the power lines myself.
Signal wire gauge and color. sparrowkc Electrical 4 10-03-2010 19:51
Spike Relay Wire Gauge sparrowkc Electrical 7 12-02-2008 14:26
Wire gauge vs. current AdamHeard Electrical 7 09-11-2007 10:36
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
11 Gauge Wire...where? Matt Krass Electrical 6 21-01-2003 10:17
