Go to Post Temp wiring is always bad but it is made worse when dealing with a $1000 part. You wouldn't try to lash a makeshift power source to your PC. - Al Skierkiewicz [more]
Unread 04-02-2009, 15:40
Re: Gyro problem
Originally Posted by Coffeeism View Post
Keeping the wires short will also help the drift(lower capacitance).
I do not believe you, yet. Can you please explain your reasoning?
Unread 04-02-2009, 21:11
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Gyro problem
The gyro produces a voltage that will charge the capacitance in the wire. The longer the wire, the larger the capacitance, longer discharge time, longer change in voltage after gyro stops accelerating. It will also catch more noise if the wires are longer.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 05-02-2009, 09:06
Re: Gyro problem
What you are describing is phase delay. Drift is where the null value (zero turn) drifts away from nominal, which is interpreted as a constant steady spin.
Your comment on phase delay is technically true, but not on a scale that is detectable. A cable that long will contribute a couple dozen picofarads. With a sampling frequency of 62,500Hz and an output impedence of 100 Ohms, you would need to add a couple hundred thousand picofarads to start to change things.
Since the gyro signal is only in the 0-200Hz(ish) range, I'd wager that phase delay will continue to be imperceptible.
However, the noise comment is very valid.
Gyro problem..HELP! zivo123 Programming 13 14-04-2008 12:06
gyro problem Guarana Programming 9 03-03-2008 15:48
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
