Go to Post Let this be a hint to the hardware teams. Deliver that robot early and give the software and driving team time with the robot. IR3 has proven it can be done. - Doug Leppard [more]
Unread 04-02-2009, 15:40
NinjaSpawn94 NinjaSpawn94 is offline
FRC #1647
NinjaSpawn94 is an unknown quantity at this point
Sidecar Debug
Does anyone know if there is a sample vi that allows you to see all inputs and outputs on the sidecar for making debugging easier? I would much appreciate it.
Unread 04-02-2009, 15:46
Re: Sidecar Debug
See team update 5 and/or the default dashboard.
Unread 04-02-2009, 15:47
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Sidecar Debug
Sounds like you may be looking for the FRC Diagnostic Window
Unread 04-02-2009, 16:13
FRC #1647
Re: Sidecar Debug
Thank you, that is exactly what i needed. Would you know how to get that to work with LabView?
Unread 04-02-2009, 16:19
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Sidecar Debug
You should have all the info you need on the page I linked to. The download link is in the top right corner of the page and the page itself has a description of how to deploy the program and what info it gives where.
If you have a specific question I'm sure someone could help you out (I haven't actually gotten a chance to use the diagnostic yet).
Unread 07-02-2009, 10:27
Chris11246 Chris11246 is offline
FRC #1647
Chris11246 is an unknown quantity at this point
Re: Sidecar Debug
When we try to get a reading from the DIOs using the Diagnostic window it shows that they all have a value of 1 even though nothing is plugged into them. Are we using this wrong.
Unread 07-02-2009, 10:48
Re: Sidecar Debug
Nope. There are resistors that set the value to 1 unless you do something to make them a 0. It seems counterintuitive at first - why didn't we make it 0 by default? The reason is that several communication methods use a "1 unless we say otherwise" standard. This allows you to easily interface with them.
No RSL on Digital Sidecar shobuda999 FRC Control System 16 08-02-2009 14:28
Digital Sidecar Problems cabbagekid2 FRC Control System 13 31-01-2009 17:23
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
connecting Jaguar to Sidecar Lakedaimon Electrical 2 15-12-2008 01:04
Missing Standoffs on Sidecar psyco_klown Electrical 3 03-12-2008 19:40
