Go to Post We are here to support each other. - Mike Martus [more]
Unread 04-02-2009, 15:50
Skyman7's Avatar
Skyman7 Skyman7 is offline
GO BIG OR GO HOME!
AKA: Skyler
FRC #2339 (Robolopes)
Skyman7 is an unknown quantity at this point
Send a message via AIM to Skyman7
Advanced phneumatics
Ok so i would like to know how you would program dual action valves. We are using a button to launch and im not sure if u need to make a progam for it to pull the phneumatics back down. Iwould appreciate nay help!!!!
Unread 05-02-2009, 23:55
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: Advanced phneumatics
From the FRC 2008 Pneumatics Manual:
http://www.usfirst.org/uploadedFiles...ics_Manual.pdf
SMC has provided two double solenoid valves and a single
solenoid valve. For the double solenoid valves, if you
pulse one of the solenoids to make the cylinder extend, you
must then pulse the opposite solenoid to make it retract.
Either solenoid may be left in the energized state. This is a
great valve to use to maintain position when the power is
turned off at the end of the match.
Radiosity or Advanced Lighting team384_pat 3D Animation and Competition 6 06-05-2004 13:28
Advanced Programmer Needed!!! punarhero Programming 7 21-03-2004 15:29
Advanced Programming Guide SilverStar Programming 0 30-01-2004 21:30
a [slightly advanced] mathematical puzzle mehtank Chit-Chat 5 28-12-2001 00:09
