Go to Post Welcome to FIRST. You've never seen anything like this. - Aignam [more]
Unread 04-02-2009, 15:50
akeisic's Avatar
akeisic akeisic is offline
Systems and Strategy Mentor
AKA: Andrew Keisic
FRC #4201 (The Vitruvian Bots)
akeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to all
Re: pic: 294 teaser
Originally Posted by Borisdamole View Post
im guessing plywood prototype of a turret , made on a waterjet at GKN. Im guessing the real part will be aluminum, and at least 3/8 thick(probably 1/2inch)...
False, True, True, False
We set a record at the GKN waterjet; the code to make the part was 3700 characters long and took nearly 2 hours to cut. The best part is that the part came out perfectly. No need to redesign or remachine here!
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
Unread 05-02-2009, 00:53
unclewaldo unclewaldo is offline
Fabrication/Assembly/Cat Herder
FRC #0911 (WestBots)
unclewaldo is a jewel in the roughunclewaldo is a jewel in the roughunclewaldo is a jewel in the rough
Re: pic: 294 teaser
We set a record at the GKN waterjet; the code to make the part was 3700 characters [ed: lines??] long and took nearly 2 hours to cut. The best part is that the part came out perfectly. No need to redesign or remachine here!
AND how to you plan to place the chamfer on the sprocket teeth?? I can think of some interesting solutions but am curious as to your plans...
.... or are you leaving them square and hoping for the best by keeping the chain tension "extra tight" since I assume this will lie in a horizontal plane....
Unread 05-02-2009, 01:04
akeisic's Avatar
AKA: Andrew Keisic
Re: pic: 294 teaser
GKN's largest lathe can handle 20" diameter parts, which is where we will be doing our work. If it really came down to it we could stick it up on our VTL we use for our 6ft diameter engine nozzles. :-)
pic: 294 Teaser #4 Drwurm Extra Discussion 3 10-02-2008 03:04
pic: 294 Teaser #3 Drwurm Extra Discussion 10 07-02-2008 02:49
pic: 294 teaser AdamHeard Robot Showcase 1 15-02-2007 03:31
pic: Team 294 Teaser #2 AdamHeard Extra Discussion 7 01-02-2007 19:40
pic: 294 teaser sojouner06 Robot Showcase 16 12-02-2005 22:25
