Go to Post Archimedes brings all the bots to the yard! - looneylin [more]
Unread 04-02-2009, 16:12
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: FP Gearbox: Last stage gear?
Normally this requires an involute gear cutter(or hob), of which there will be several for the same Diametrical Pitch value, as the profile of the cutter needs to change a bit due to the number of teeth. You can also grind a peice of tool steel to make a form tool and use it as a single point cutter. OR if the tooth profile is large enough, you can use a properly sized end mill to cut the gear on a 3 axis mill. However this would likely be a very hard thing to accomplish(in something other than plastic / wood), for reasons I wont go into here. So, if you have a 4 axis CNC or a manual mill with a dividing head, or rotary table look into the involute gear cutters.
If you want to search around some, another word for gear cutting is hobbing.
Here is one example
http://www.youtube.com/watch?v=VHTXa...eature=related
and here is another, using a different style cutter
http://www.youtube.com/watch?v=62yme...eature=related
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
AM Planetary Gearbox (removing the fisher price gear/buying one without a gear) Ice Berg General Forum 10 04-02-2009 15:43
Last Year's Gear Ratio AndyB Technical Discussion 4 11-11-2007 01:17
BaneBots 56mm Gearbox - Second Stage Sun Seizing Gary Bonner Motors 18 10-02-2007 12:52
Last year's gearbox MishraArtificer General Forum 3 10-01-2007 10:57
Worm Gear Gearbox dddriveman Technical Discussion 38 07-01-2005 14:43
