Go to Post ..the way we see it FIRST isn't about winning a robot contest, its about trying your best to complete a really really hard task in a really really short amount of time. - Stuart [more]
Unread 04-02-2009, 15:43
Yuan Xue Lim's Avatar
Yuan Xue Lim Yuan Xue Lim is offline
Electrical Programmer
FRC #3017 (Project Genesis)
Yuan Xue Lim is an unknown quantity at this point
Send a message via AIM to Yuan Xue Lim
Battery voltage
We are recently facing a huge problem-indicating the battery voltage.
On the DS it shows 00.00V
the analog breakout is not lighthing:
*the wire is connect to the write place
*we used the right type of AWG,amp breaker
*the +/- charges are right
we even try the new analog breakout
We ran out of thought
so any idea of how to fix the analog?
Thanks
[font="Fixedsys"][b]We Don't Hope We will.
Unread 04-02-2009, 16:02
Electrical Engineer
Rookie Year: 1995
Re: Battery voltage
Did you install the jumper on the analog breakout?
Mike Betts
As easy as 355/113...
Unread 04-02-2009, 16:17
Re: Battery voltage
o forgot to mention that
yes we did
the analog LED is not even lighting up
Unread 04-02-2009, 16:29
krimpetsrgood93's Avatar
krimpetsrgood93 krimpetsrgood93 is offline
AKA: Steven Wills
FRC #1647 (Iron Devils)
krimpetsrgood93 is an unknown quantity at this point
Re: Battery voltage
We fixed this problem. You have to replace your cRIO image. Everytime the software is updated, the cRIO image must be updated as well, or you will run into this problem. You go to the CompactRIO Imaging Tool.
Hope this helps.
Unread 04-02-2009, 16:34
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Battery voltage
Sounds like the Analog Breakout is not getting power. If you are sure that the wires are running to and from the correct places there is one more big thing to check. You have to make sure that the Wago terminals are grabbing onto the wire only and not the insulation. This appears to be a common problem with these new terminals.
Unread 04-02-2009, 17:10
Re: Battery voltage
THANK YOU VERY MUCH
YOUR METHOD WORKS
Unread 04-02-2009, 23:01
Re: Battery voltage
Let's not accidentally blame the terminals themselves. It's more of a problem with people not carefully following the directions for how many millimeters of wire to strip.
Unread 04-02-2009, 23:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Battery voltage
I love the terminals, although my post does sound a bit like I'm blaming them. What I meant was more along the lines of the fact that the terminals are new and people haven't figured out all the ins and outs of them yet.
Ideally everyone would read and follow all the directions, but we all know that in practice this is not always the case.
System Battery Voltage is wrong 3DWolf Programming 12 03-02-2009 20:31
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
Battery voltage Josh Siegel Programming 5 22-12-2003 10:15
Battery Voltage Neal Probert Programming 3 09-01-2003 10:18
