Go to Post Only two letters and one punctuation mark can describe my feelings about this... NNNOOOOOOOOOOO!!! :( - Qbranch [more]
Unread 02-02-2009, 20:02
reflion reflion is offline
Design Team 2204
FRC #2204 (Rambots)
reflion is an unknown quantity at this point
Does anyone have the mechanical specs for the Denso?
Or, failing that, does anyone happen to know what size screws you would use to mount it?
Unread 02-02-2009, 20:09
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Does anyone have the mechanical specs for the Denso?
Quick answer just in case you're in immediate need, then others can follow with the real data later--
The two black holes are #10, and iirc they're spaced ~2-1/8" apart, or just slightly more than that I think; I only had a ruler with 1/8" increments when I made a mount this passed weekend and I had to slightly adjust the holes I drilled.
The third, metallic hole seems to be the right size for 1/4" bolts, yet neither 1/4-20 nor 1/4-28 bolts fit...which leads me to believe all of the holes are meant to be metric.
GitHub
Unread 04-02-2009, 18:53
Design Team 2204
FRC #2204 (Rambots)
Nobody knows about that last hole yet? Or does anyone have a good way to take that metal insert out of the hole so we can modify the hole size?
Unread 04-02-2009, 19:26
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
I drilled it out with a 3/16" drill bit, and used a #10 bolt.
Unread 04-02-2009, 21:35
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
The top hole is metric. I do not remember the exact size, but I know it is metric. We took ours to the hardware store and tried screws until we found one that fit properly.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 09-02-2009, 22:31
Design Team 2204
FRC #2204 (Rambots)
Also, our electronics team needs to know what kind of wire they need to use to attach the Denso--anyone know or can anyone refer me to the documentation?
Thanks in advance!
Unread 10-02-2009, 00:35
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
The metal insert is M6. The attached specs are from 2006.
Unread 10-02-2009, 08:07
AJ R's Avatar
RoboGeek
Page 8 of the tips and good practices from 2007 includes motor data. Other motors may be different, but the window motor is the same.
http://www2.usfirst.org/2007comp/oth...tices_RevC.pdf
AJ
Does anyone have a digital copy of The Gates Brochure/ Drawings fordchrist675 General Forum 0 07-01-2009 16:58
Does anyone have information on the following teams? Michael Hill Scouting 4 15-03-2007 23:13
Does anyone have a schematic for the operator's panel? DHarris Technical Discussion 1 28-01-2006 10:46
Does anyone have pictures from the FLR? Ashley Christine Regional Competitions 8 11-03-2005 15:14
Does Anyone Have the numbers? archiver 1999 4 23-06-2002 22:20
